How to rewire seril pin exsample what pin is r input and what pinis sub ect...
Pin 1-G
pin 2-R in
pin 3-L in
pin 4-PG
pin 5-R out
pin 6-ST BY
pin 7-VC
pin 8-L out
pin 9-PG
This is awesome. Thanks so much for posting this. What is "PG"? I assume "VC" is volume control.
Thank you for figuring this out and posting it. What does PG stand for?
Use the G as the ground for your line in. Use the PGs for your grounds for the L out and the R out. Really doesn't matter which. As they say: Ground is ground the world around.
nice job bro. i'ved tried it. ;-)
what porder are the pins in
what do PG, VC, ST BY stand for? mine not working and trying to see if transformer OK. which two pins would I need to test? transformer says 17VAC.
PG ground, VC operating voltage, ST BY stand by voltage.
may i know what is the value code of 17pins audio IC of Dell a525 zylux subwoofer?
What is the Voltage measurement on the VC Going in? What is the voltage on the ST-BY going in?
How to on manual with cable touch
Can anyone complete like this for beginners like me : (L spkr: -=..\ +=..)
R spkr:(-=../+=..)( input+=...) (Input-=...) Volum...
SOURCE: Dell HK 395 Speaker System - Need Circuit Diagram Download
1. Check the orange multi-pin connector the sufwoofer for a broken or bent pin. If there is a broken pin you can bypass it by cutting open the cable jacket and tap onto the affected wire with a 6 inch or so jumper, and then attach a jumper to the appropriate point inside the subwoofer. Pass the subwoofer jumper out of the case (drill a small hole) and connect it to the jumper you added to the cable.
2. Try wiggling and rapidly rotating the volume control. There are reports this control may become a problem as it ages.
3. I haven't been able to find a schematic. My only recourse was to google the output amp and the 2 op-amp packages for data sheets. They are readily on the internet. Then I laboriously traced out the stereo paths. I found that red and black fine tip felt pens were helpful in marking out the signal paths through the circuit boards.
SOURCE: I have a Dell/Zylux A425 2.1 audio system for a
necesito los controladores para el subwoofer a425 esque compre la bocinas pero no me las lee porfabor un link o si tiene los controladores fabor de enviarmelos al correo [email protected]
Thanks! Does anyone know if there is a way to hook this sub up to a home theater receiver that requires a powered sub?
That's what I am working to do.
