Cars & Trucks Logo
Posted on Dec 28, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Front passenger door lock wont work, seat belt light on
Can't open front passenger door. Door key won't work from outside. Neither can door be opened from the inside.
Also the seat belt display is continuosly on with no one riding in the passenger seat.
  • Anonymous Mar 18, 2014
    sonata
Anonymous
Level 3:
Master:
  • Master 426 Answers
  • Posted on Dec 28, 2008
Anonymous
Master
Level 3:
Master:
Answers
426
Questions
Helped
205686
Points
1323
Sounds like the plastic clip that connects the lock has broken however regardless of fault the inner door panel has to be removed to diagnose and repair.It could also be inner door lock assembly.
1helpful
2003 nissan 350z. Passenger door electric locks only unlock half way. Problem is I can get door panel off being door is shut and cant open from outside/inside.....What now lol
Remove the front seat can give you access to remove the panel. But if it has screws around the outer perimeter, most likely will have to tear it out. Best to find a replacement first. Look at the drivers door, if it has screws, so does the passenger side. There are screws around the arm rest and door handle to remove, then it pops off. Again the seat has to be out of the way.
Passenger door can be opened from inside but not from outside...how too fix???
2781506 The front passenger side door won't open
45.32.21.64/F/cars/t2781506-front_passenger_side_door_open
Solution: Elect lock activator inside door either weak or is binding not pulling lock all the ... Right passenger door wouldn't open from outside, then my kid turned on the interior ... civic door won t open from inside or outside fix no drilling ... Has recently started to just suddenly lose power and stop but i can start it again and it ...
Passenger door won't open ' Forums ' Tesla Motors
www.teslamotors.com/it_IT/.../passenger-door-wont-open
Tesla MotorsFor some reason, the passenger side front door will not open when pulling on the handle. We have the tech ... There's nothing you can do to fix it yourself. ... I tried locking and unlocking it at the restaurant and that didn't work so I just opened it from the inside. ... Handles extend, lights work, but I can't open from the outside.
Fixing A Car Door That Won't Open - YouTube
2answers
Why won't the door(s) unlock on my 1975 Chevelle Malibu Classic?
Does the passenger door unlock with the key? If it is OK, then the lock mechanism or the linkage has a problem. You will probably need to remove the interior door panel and examine it from that angle.
Cant get front passenger door to open 2001 kia rio
Key turning in the lock does not necessarily indicate it is working. You will have to remove the inside panel to get access to these parts. There are different ways in which a key lbock serves to prevent the latch from working. Most likely, the key operates a rod to the latch (if the key socket is seperate from the latch. If the key socket is within the handle, then probably you will have to drill out the key hole from the outside that should free up the latch. Then you will have to get a replacement latch and key section. Most of this becomes evident by observing the mechanism from the inside of the car. Depending on how tight the passenger seat is relative to the door panel, you may have to remove the seat. Even if you send up going to a locksmith, removing the inside parts will speed up his operation and save money.
2helpful
1999 aurora front door won't open from outside with either remote or key won't open from inside with handle
If you can't open the door you can pull the corresponding seat to gain access and remove the inner door panel
1992 chevy lumina door wont open at all
will it open from inside? If it will then you didn't hook up the linkage right on the outside handle
Top Pontiac Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Pontiac Expert? Answer questions, earn points and help others
