ITT Jabsco Jabsco 135 Sl Remote Control Searchlight Replacement Bulb Logo
shirley Alford Posted on Sep 23, 2012
Need wiring diagram for jabsco 135 searchlight
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 14, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
4254
Points
I have an older unit, but this might help...
Thick Black wire is Earth or Ground
Thick Orange wire is Spotlight feed +
Thick Grey Wire is Flood feed +
Green and brown wires are motor up/down
Yellow and Blue are motor Left and right.
  • Anonymous Apr 05, 2018
    From switch control there's
    a fused red
    , orange , double black, blue, yellow, brown and green . from light all the same but has no orange , only red. All wires on both light and control are small gauge wires , only large one or the red fused wire
Where can I buy the reflector for a ray-line #41120-1110
Did you ever find a source? I am looking for a bulb for this same unit, and also a gear mechanism for tilt.
Jabsco 146sl repair
I am looking for a manual for a jabsco 60080-0012?
Need bulb for 41120-2110
Did you ever find a bulb? I need one too.
4helpful
Light turns on and moves up and down but will not go from side to side only clicks, I removed the light and the gears looked good. could it be the control itself?
Chances are that it may be a ceased motor assy.
I had same problem & solved it by replacing motor assy.
Suggest unwire it & remove from unit and apply 12v to terminals (either way round)
If the gear wheel does not turn slowly then that is where your ploblem lies.
Replacement motor not excessively expensive.
I have a jabsco 8'' searchlight, it slews however the light went out, is this replaceable or is a whole new unit needed.
Seems like it MUST be replaceable. Look it up on the net. http://www.google.com/search?source=ig&hl=en&rlz=1G1GGLQ_ENUS331&=&q=jabsco+searchlight+parts&aq=1&oq=jabsco+searchlight
Jun 16, 2009 • Boating
17helpful
Need a wiring diagram for a massey ferguson 135 tractor
I need a wiring diagram for my massey ferguson 135 tractor regards ****
Top ITT Jabsco Boating Experts
ADMIN Andrew
ADMIN Andrew
jws1013
Kardoc
Are you an ITT Jabsco Boating Expert? Answer questions, earn points and help others
