20 Most Recent RTO Massey-Ferguson Tractor TE20, TO20, TO30, ITFE2 Questions & Answers
3answers
Who has manuals for the Massey Ferguson 230?
contact the manufacturer on line for any available pdf downloads. try e-bay for manuals.
11/1/2022 12:00:51 PM • RTO... • Answered on Nov 01, 2022
4answers
MF Tractor 265 diesel engine fuel problems.
I ran into the same problem and found the line to the tank was clogged, take your line loose and see if your fuel flows freely if not blow some air from a compressor back up the line and into the tank. Hope this helpls
3/30/2022 9:07:01 AM • RTO... • Answered on Mar 30, 2022
I need a wiring diagram for a Ferguson TO30 Z129 thats been converted to 12v already with a ford 1g alternator
Not sure you'll find a wiring diagram for a Massey that has been customized, unless you create one yourself. You can try your local authorized service center or contact online here: http://www.masseyferguson.us/about-us/contact-us.html helpful-fbhtsuujths3pkuos2jmb534-4-0_12.png
2/9/2018 5:15:06 AM • RTO... • Answered on Feb 09, 2018
TO-30 quit running, puff of smoke from electrical? Won't turn over
It is possible to have the solenoid go bad but not while the tractor is running as it is only used to engage the starter. It sounds like the wires to the starter is shorted out. I would run a hot wire to the solenoid from the battery to the solenoid and see if it will start. Just be sure everything is grounded. If the ground cable on the battery is ok you should not have a problem with running a hot wire to the solenoid. Just touch the hot wire to the starter and then release it when the starter engages. Hope this helps.
4/16/2017 11:42:59 PM • RTO... • Answered on Apr 16, 2017
The arms on my Massey Ferguson 230 fell to the ground..the hrydri don't work at all.
check your hydraulic suction screen
6/16/2016 1:18:16 AM • RTO... • Answered on Jun 16, 2016
Massey ferguson tractor wont start, starter wont even turn over
check your ground to the starter, if thats ok try tapping on the outside of starter body while trying to start engine, the starter may have a dead short in it
5/30/2015 12:57:31 AM • RTO... • Answered on May 30, 2015
2answers
35 gas massey ferguson tractor new carb,new
If you're not having any electrical issues then Check the governor.
3/28/2015 12:28:47 PM • RTO... • Answered on Mar 28, 2015
2answers
I have a Ferguson TE20 petrol starts fine runs 5
Sounds like a bad ignition condenser. Many nowadys aren't worth spit, and you may wind up going through a few until you find a good one.
2/22/2015 6:22:04 PM • RTO... • Answered on Feb 22, 2015
2answers
I have a te20 tractor and the 3point hitch won't lift or go down . why ?
The hydraulic control valve for the hitch is not opening correctly, take it apart and clean it If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
2/22/2015 6:05:09 PM • RTO... • Answered on Feb 22, 2015
Need wiring diagram for a TO30 Ferguson Tractor
Check out our Resource pages at www.fergusontractors.org and if that doesn't give you what you need email our Ferguson technical advisor, Robert Sybrandy at [email protected]
2/11/2015 3:47:42 PM • RTO... • Answered on Feb 11, 2015
0answers
0answers
Z129A600
Be the first to answer 9/8/2014 3:05:35 AM • RTO... • Posted on Sep 08, 2014Be the first to answer
RTO Massey-Ferguson Tractor TE20, TO20, TO30, ITFE2 Logo
265 questions posted
Top RTO Toys Experts
Jay Finke
Jay Finke
ADMIN Eric
ADMIN Eric
Jerry Ross
Jerry Ross
Are you a RTO Toy Expert? Answer questions, earn points and help others
View Most Popular
RTO Toys
  • RTO Toys
Most Popular Question
farmall 140 insttalled new solenoid
  • Toys
