Fisher Price Power Wheels Kawasaki KFX Ninja Ride-On Toy Logo
Posted on Sep 21, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
WHAT IS THE CHEAPEST REPLACEMENT BATTERY FOR A 12 VOLT POWER WHEELS
MendingShed.com
Level 2:
Novelist:
Scholar:
  • Expert 134 Answers
  • Posted on May 21, 2015
MendingShed.com
Expert
Level 2:
Novelist:
Scholar:
Answers
134
Questions
0
Helped
109205
Points
435
Power Wheels uses a very specific connector for their 12V batteries. It is possible to change over to another system but it is recommended for the safety of the child to only use a Power Wheels genuine 12V battery. The part number for the 12V battery is 00801-0638. We sell them here @ Genuine Power Wheels Replacement 12 Volt 6 Volt Batteries
You can also buy the battery at Toys R Us, and usually off of amazon as well. I do highly recommend using only genuine Power Wheels parts only on the vehicle.
-Colleen @ MenidngShed
WHAT IS THE CHEAPEST REPLACEMENT BATTERY FOR A 12  - cheapest-replacement-battery-12-volt-aw50gwa4mhkohjwvsycwbdmc-1-0.jpg
Adam Fjeld
Level 3:
Genius:
  • Fisher Price Master 1,508 Answers
  • Posted on Sep 21, 2012
Adam Fjeld
Fisher Price Master
Level 3:
Genius:
Answers
1508
Questions
0
Helped
542725
Points
1761
I sell them for $35 shipped to your door, its a 12v 12ah sla battery so you'll need to take the connector off of the old battery and solder it onto the replacement
I need a replacement 12 v battery for the NASCAR Dale Earnhardt Convertible ride on white car... what type do I need to get?
The 12volt power wheels battery for this can be found at Walmart or most any store that sells power wheels ride on vehicles
2answers
Typ of battery
Mine has 2 12 volt 12 ah agm batteries model ub12120 if that helps>
I am building an off grid cabin but will need to meet code providing all electrical components as per the latest NEC. I will be using a 4100 watt generator for my initial power source but plan on...
I think he cost of the panel and breakers would be the cheapest thing on your list. Your 4100 watt genny is tiny for a whole house, and if you are planning on a solar set up, you will need to convert to dc, so, I take it your 4100 genny is used to charge the battery bank? Then the panel will not need to be anything but a small disconnect for the genny, basically one of those things that prevents the current from flowing back into the source, which you don't have. I would talk to the building dept., they may not want to take liability, and make you get a contractor to figure something out. All your appliances, and lights will be 12 volt, most motors are 12 volt anyway, they are just transformed to 12 volt from 110 current, and I don't think you will need breakers for 12 volt stuff. You could look at some camper supplies, boat stuff, they all run 12 volt appliances, and lights.
2answers
Battery pack is broken, need a replacement. Anyone know where I might find
Meade may be able to replace this. Call them here:
http://www.meade.com/support/index.html
2helpful
12 volt direct connection with battery
Never try to connect a laptop directly to a battery.The voltage might be 12v or slightly more but the current is a lot more than even what you get from the mains..So if you really want to connect to a battery you will need a power inverter which I think is the cheapest solution.You can get one off ebay for 10usd roughly for a 50watts inverter.Hope this helps.
2answers
PARTS FOR POWER WHEELS EXTREME MACHINE
Power Wheels only makes the battery connector available as part of the whole wiring harness. There are several parts that Power Wheels will not sell directly to consumers, these usually include the wiring harness, motor/gearboxes and the switches.
If you do need the motors, battery & wiring harness it is most likely not worth repairing. That being said the Xtreme Machine is no longer made by Power Wheels, and the closest thing would be the Dune Racer they now produce. So if you are really wanting the machine repaired you will have to take it to a Authroized Power Wheels service center and have them repair it for you.
The battery you can purchase usually off of Amazon, Toys R Us or from one of the many service centers like us. Power Wheels put two different style batteries into those vehicles depending on the year made. So it may either have 2 6V Red batteries or it might have 1 12V Gray battery. Here is a link to the batteries on our site:
As for the motors & the wiring harness you would need to contact you local service center. Here is a link to the service center locator: Mattel and Fisher Price Consumer Relations Support Center Power Wheels...
Also before you get too far into this project be sure to look at the new vehicles they make that are very similiar: Power Wheels Products
11helpful
2answers
I want to replace my Power Wheels battery w/lawn mower battery.
If it is a 12v power wheels, a lawnmower battery will work. I have done it on model # 73690-9993. Make sure you mark the wires on the connector pos(+) and neg(-), should be White for + and Black for -. Then cut the wires and install ring terminals that will fit the lawnmower batt. I would remove the batt. to charge it. **** will on work with 12 volt Power Wheels.****
2helpful
5answers
12 volt rechargeable battery
Walmart has them> I would definately buy from them because if you get it home and then find out that you  have other problems than a new battery, you can always take it back.
Top Fisher Price Toys Experts
ADMIN Andrew
ADMIN Andrew
Jennifer Rock
Jennifer Rock
NOEL
NOEL
Are you a Fisher Price Toy Expert? Answer questions, earn points and help others
