20 Most Recent
Your One Source Homeline Load Center, 200 Amp Questions & Answers
Are HomeLine 20 amp circuit breakers the best for an average home?
Depending on the electrical panel you have installed... some breakers of different Mfg's can be used in the panel... you would have to validate the "Physical Fit" at the store where you are purchasing... however... putting in breakers of different Mfg's will not look like the panel was professionally installed.
I would like to use the same or exact replacement for the panel Mfg.
the cost cannot be that much different... and buying exact replacement should give you piece of mind. Btw, I’m available to help over the phone in case u need at
https://www.6ya.com/expert/lisa_52daba487e5b4d53
How do i know which breaker goes where into my
If the installer didn't fill in the label inside the door you're relegated to turning one off and checking what turns off in the house. You can do this by yourself but it's a lot easier with someone in the house to tell you what shut off as you switch off each breaker in the box. Use things like plug-in lamps or hair dryers in outlets to know when they go dead.
How is power source connected tobreaker unit
I presume you are identifying the power source as the power coming from the electric company. If this is the case, and you have no expertice in these matters, you should get a qualified electrician to bring the power in to the load center. This is a very dangerous task for a qualified person, and possibly terminal for a novice. Your power could be coming from a pole in the alley or an underground vault. You have not given sufficient information for either.
I am trying to install
I'm assuming since it's a Homeline panel you're using a HOM2100 breaker. If it stripping then you must have a short circuit in your 100A circuit, or the breaker is defective. Disconnect your load from the breaker, and turn main on. Be sure you have the correct load conductors connected to the breakers. Typically red and black on the breaker, white on neutral bar. Bare to ground bar
I have a 200 amp service panel i have a 100amp
Theres a few different ways to set up the secondary panel. The most efficient way, in my opinion, would be to set it up as a subsidiary. This is a really great way to allow power to be shut off for sections of a house instead of killing everything. This requires wiring it to the main panel on a breaker which will serve as the main for the 100amp subsidiary. Obviously this will require that a comparable breaker be installed in the main 200 amp panel to support the new subsidiary 100 amp panel.
Here's where it gets tricky and you really should either consult or contract a licensed technician. Because the amperage rating does not dictate the amount of power that is supplied to your house on the primary line you are essentially using the new box as a splitter. The danger in this is that just like any common electrical outlet, the more stuff you plug into it the more likely you are to overload the circuit and risk catastrophic failure, like a house burning to the ground or worse.
Knowing that your panel is side by side, you should be fine with #2 AWG, I would confirm electrical code before installing and ensure that grounds are diverted to the main panel to avoid the risk of running live current through the otherwise 'safe' ground.
If you are installing the panel to increase the amount of breakers it is probably safe to assume that there has been some previous work done that fills up the main panel. I would strongly encourage you to talk to an electrician about your needs and the changes in your house that require the additional breaker slots. There is a certain amount of artistry involved in 'designing' the house and you could probably accomplish the same end result with one panel and a more efficient wiring plan.
I am building an off grid cabin but will need to
I think he cost of the panel and breakers would be the cheapest thing on your list. Your 4100 watt genny is tiny for a whole house, and if you are planning on a solar set up, you will need to convert to dc, so, I take it your 4100 genny is used to charge the battery bank? Then the panel will not need to be anything but a small disconnect for the genny, basically one of those things that prevents the current from flowing back into the source, which you don't have. I would talk to the building dept., they may not want to take liability, and make you get a contractor to figure something out. All your appliances, and lights will be 12 volt, most motors are 12 volt anyway, they are just transformed to 12 volt from 110 current, and I don't think you will need breakers for 12 volt stuff. You could look at some camper supplies, boat stuff, they all run 12 volt appliances, and lights.
Subpanel hookup
Yes the maximum size branch circuit breaker that will fit in a residential load center is 100 amps. I would recommend that you calculate the amount of power that you need the sub panel to handle, then add any additional loads you may need in the future. Hopefully this is less than 100 amps. I would recommend that you check with your local electrical inspector to make sure your installation meets all local and national codes before proceeding with the install.
Delette facebook mobile
Go to my app store, find the my apps look for Facebook click on it and press the uninstall button. it should take a couple of sec.
My conlog meter is showing the rfcon error please what do I do
No connecting to your utilty company in South Africa. Just FYI, we are a North American site and my not always have the answer, in this case we do
Https://www.facebook.com/ConlogSolutions/posts/im-having-a-rf-con-error-cant-do-anything-on-the-gadget-please-help-on-how-to-re/962048393965724/
Quoting from link above: "
Conlog Hi Ola-daniels, Please see below steps to assist with RFCON error :
* Press the Back arrow on the keypad - this step is to refresh the UIU ( the device)
* Type # 75 # - this is to check the signal strength
If it does not go back to the normal display
*Type # 80 # - this is to refresh the meter
Then lastly you can repair the meter and the UIU by # 36 #
The above steps will work better if you are outside the house because the meters uses the radio frequency connection
The above error will occur in instances of bad weather conditions or if there is load shedding or power failure
If the problem persists after trying the above you may contact the municipality or the service provider."
SOLVED: How do I clear up the rf con error on my meter ...
https://www.fixya.com > ... > The
May 7, 2020 - How do I clear up the rf con error on my meter because I want to ... Https://www.facebook.com/ConlogSolutions/posts/im-having-a-rf-con-error- ... Hi Ola-daniels, Please see below steps to assist with RFCON error : ... shut down the energy alimentation for 2 minute ,but if the defect persist error it show again.
SOLVED: Pole meter conlog rf con meter keep on freezing ...
Jan. 10, 2017
Meter reading shows rF CON instead of units available - Fixya
Jun. 24, 2018
SOLVED: Good day my conlog ip54 elecricity meter showd ...
Oct. 6, 2018
SOLVED: Rf con error - Fixya
Jun. 20, 2020
More results from www.fixya.com
Please Help With My Conlog Prepaid Meter - Technology ...
https://www.nairaland.com > please-conlog-prepaid-meter
Aug. 6, 2020 - ystar: If the conlog meter is showing rf-Con, it means power supply doesn't reach the meter at all its either Loss of phase from the transformer or a loose contact ...
How Do I Load The Activation Token On My Conlog Prepaid ...
Mar. 17, 2020
I Need A Technician To Fix This... - Nairaland / General - Nigeria
Jul. 22, 2019
I Need Number Codes To Reset Memmcol Prepaid Meter ...
Jan. 11, 2019
More results from www.nairaland.com
