Cameras Logo
Michel Goujon Posted on Sep 18, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Fujifilm Fine Pix 80 EXA
I'm busy with a Fujifilm Fine Pix 80 EXA which received some salt water. I opened all, dissassemn=$bled what can be and everything looks cle=an except the connectuion to the display. This connector was dirty 'green du to copper salts formed with salt water) . Now everything looks clean ... how to restart it ? Is there any reset procedure ? ? [email protected]
Anonymous
Level 3:
  • Fuji Master 32,281 Answers
  • Posted on Sep 19, 2012
Anonymous
Fuji Master
Level 3:
Answers
32281
Questions
Helped
7913453
Points
102259
Salt water may have caused some components to short out.
It would not be worth repairing and it would not be a DIY repair.
5 Related Answers
Anonymous
  • 277 Answers
  • Posted on Apr 03, 2006
SOURCE: lcd screen blank
hi yes salt water is very dangerous for any electronic device and it is possible that you will need to install a new LCD but first try changing the battaries to brand new 1's a little slap on the bottom side will maybe do the job good luck
Anonymous
  • 12 Answers
  • Posted on Nov 17, 2008
SOURCE: Nikon d200 sprayed with water
I would suggest that you give the contacts a good clean (gently of course) on both the camera body and lens'.
Also although the water would make no difference, make sure if you have any lens' with aperture rings to put them round to F33 or the smallest aperture, if they aren't this will cause the fEE.
Hope this helps
Drew
fikretunalir
FIKRET UNALIR
  • 239 Answers
  • Posted on Feb 03, 2011
SOURCE: My kodak m530 got salt
Of course this problem is fixable. But the question should be asked as such that ; can it be economically fixed? The answer is Unfortunately.
There is a few ways to solve it.
One: To repair it by changing the capacitor of the flash with a similar out of order camera. But this needs an authorized tecnician and to have similar camera. But this is not an easy way.
Two: To change the flash unit as a complite module by the help of an authorized service. But this is very expensive according to a new camera.
Three: Not to use the flash but going on to use the other parts of the camera. I think this is the best thing to do.
Unfortunately I could not solve your problem but I have given you detailed explanation about what can be done.
Regards.
Anonymous
  • 752 Answers
  • Posted on Jul 04, 2011
SOURCE: FujiFilm Fine Pix A805 Does my
Based on what the manual says, no it does not take B&W photos.
Anonymous
  • 181 Answers
  • Posted on Aug 31, 2011
SOURCE: FujiFilm fine Pix A 345.
Those things get stuck.
You have to mess with it until it comes unstuck, if it even does.
Try hitting it while you are turning it on. Tap it from all sides and directions.
You might get lucky.
I got mine to come back to life temporarily.
Please don't give me a thumbs down just cause its bad news.
Fujifilm FinePix JX360 Digital Camera. When switched on the lens comes out but the lens cover does not open even when you take a photo. The photo just shows a slot of light.
Question edited for clarity and correct name of camera, plus typos.
Question moved from 'Pix Cameras' category to a better one.
Videos that may help, but I would advise taking it to a local camera shop for professional repair.
https://www.google.com/search?q=fine+pix+jx+360+lens+cap+repair
1helpful
Can't insert 8GB fujifilm card into Fujifilm fine pix A330
The A330 uses xD Picture Cards, which top out at 2GB. Your 8GB card is some other type (most likely SDHC) which will not work in the A330.
Fujifilm fine pix f20
There is software you can purchase in an attempt to retrieve your photo's go to www.ebay.com Type: picture recovery a list of sellers will pop up to give choices, also check www.download.com and type same notation.
I paid for a manual for a fujifilm fine pix a820 & received the wrong manual. This camera is for a B D gift. I need the manual ASAP.
You can download the manual here for free.
Have you tried contacting the vendor who sent you the wrong manual?
Oct 25, 2011 • Cameras
4helpful
2answers
What is a code 93?
Code 93 = Good News for You! :-D It is your Saltwater Chlorinator's way of letting you know that it is working properly and your pool's water has a level of salt that is optimal/good.
Code 93 just lets you know it is not actively converting salt to chlorine...it is in 'standby mode.' When you first programmed the number of hours you wanted it to run (by pressing the left (down)arrow until you heard the beep, then pressing the right (up) arrow until you heard the beep - then pressing up until you reached the desired number of hours you wanted the unit to operate (minimum 1 hour, maximum 12 hours)) the unit began converting salt to chlorine immediately.
This is good news for you. Once the number of hours of operation are up, your unit will give you a code when you press either button. If your salt level is too low, you will receive code 91 indicating this, if your salt level is too high, you will receive code 92 indicating this, if the water flow is too low, you will receive code 90 indicating this (this gives you the opportunity to correct this before the next cycle begins. If there is no error with your pool's water, your unit will go into standby and wait until it is time to run the numbers of hours you programmed it for (it will begin it's cycle at the same time each day unless reprogrammed by you). When this happens, you will find code 93.
So, just to recap:
Code 93 = Good
Code 92= Salt level too HIGH (Empty approx. 20% of pools water & refill with fresh water.)
Code 91 = Salt level too LOW (Add salt.)
Code 90 = Low Water Flow (Check your filter. If it is working properly, you may find that it is too small for your pool. The filter that came with my pool was FAR TOO SMALL - I spent more time cleaning the pool than swimming in it. My 18' x 4' pool came with a 1500 filter. Now, I have a 4000 Sand Filter. This + the Saltwater Chlorinator = practically no maintenance. Together, these were approximately a $500 investment. WELL WORTH IT!!!)
Code 88 = Startup mode. (Press down arrow until you hear the beep. Press up arrow until you hear the beep. Press up arrow until you have the unit set to operate the number of hours you desire.)
As an extra FYI: The unit works with the sun. This means the unit turns the salt from your pool into natural chlorine which is then sent back into your pool. The sun turns this natural chlorine into salt. Your filter sends this salt into your saltwater chlorinator where it is again converted into natural chlorine & returned to your pool where then sun...I think you get it. ;-) It's a continuous process. ~This being the case, when you program your saltwater chlorinator, it is best to set it up to help it work with the sun rather than setting it up to compete with the sun. You do this by programming it to run at night. This way, your unit isn't working hard to generate chlorine at the same time the sun is diligently converting the chlorine to salt. I've read several articles where people argue that you should run your saltwater system at night & your filter during the day. I don't understand this concept. My filter runs 24/7 & my saltwater chlorinator runs 12 hours - from 8pm to 8am. Since I set my pool up to operate this way, I have not had to clean it at all other than backwashing the filter every other month just for principle. My water is crystal clear.
One further note of interest: My pool holds approximately 6000 gallons of water. For this, Intex recommends 135 pounds of salt. Because of some advice I'd read posted by other users, I started with only one 40lb bag. This was all my pool needed. Approximately once/year, I add one more 40lb bag.
RJBALLZER777, because you are receiving code 93, I realize you have set your pool up correctly and, therefore, are possibly thinking, "Why is she telling me all of these things I don't need to know?" I apologize if that is what you are thinking. I am really posting for those who have not gotten it just right the first time (or who are doing their research before buying as I did) so that they may get several questions answered at once. Hope you don't mind that I used your question as a means to post. (That's why I answered your question right off the bat.) Hope this post helps some.
Hi, I don not know how to charge my new camera. I bought from ebay and was provided with a uk adapter but still at a loss. No manual instructions were given.
The adapter is the charger. You can find the manual here:
FinePix Z37
The file is in PDF format. If you can't open it, download free adobe reader here:
PDF Reader
Thanks for using Fixya!
1helpful
I don't have a problem, just a question. I recently purchased a home with a GE Smartwater softening system installed Model GXSF23Z01. What do I need to do to maintain this system. Does it require salt?...
Check the time of day, and make sure it's accuate. Reset if necessary. Add salt if it's low. It's always best to let the salt level run low (about 1-2") so it doesn't mush. Only add 80-100 lbs at a time for best results. This particular softener doesn't keep a water level in the tank, so you won't see any water in the salt area. If there is standing water in the salt area, that could mean it's not working the way it should. Here is a link to the owners manual. It's in PDF format
http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=003674144.PDF
Ihave a fine pix z20. The LCD screen is not working. The camera still takes pictures fine and the card prints the pics fine but the screen is just white with a grey line through it. I forgot to register...
If you still have few days warranty, call Fuji at 1-800-800-3854 , select option 1 and register your product, or check the website. They will tell you if the camera is still on warranty.
Here also US website.
Fujifilm: Support & Contact Center
If you leave outside US see fuji website for contact:
Home | Fujifilm Global
FUJIFILM Australia
FUJIFILM Europe
2answers
Fine Pix software installation cd
Just go to the FujiFilm website. All the downloads are available there. Download and install.
Jul 22, 2009 • Cameras
Top Fuji Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Fuji Camera Expert? Answer questions, earn points and help others
