1992 Lincoln Town Car Logo
Fred Kemper Posted on Sep 15, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Bouncing at higher speed
At 65 or higher my 92 Lincoln's front end will bounce and shake.Does it have shocks on the front end?
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Jun 15, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
529
Points
I have same problem at high speed my car will start to shake up and down it's the tire's. the tire's need a tire rotation. and or the tred is uneven put your front end on jack's and spen the tire's and see if the tire tred is flat=good tred goes up and down=bad
hope this help's :)
Stephen
Level 3:
Top Expert:
  • Lincoln Master 21,873 Answers
  • Posted on Sep 17, 2012
 Stephen
Lincoln Master
Level 3:
Top Expert:
Answers
21873
Questions
0
Helped
6210386
Points
67230
It has regular shocks on the front.
4 Related Answers
Anonymous
  • Posted on Apr 22, 2009
SOURCE: front suspension issue on lincoln navigator 2003.
Hello, mister Paul I can fix your problem first you need to see if your old bag is inflated if not find a new one. Stay cool turn down the A/C and crack a cold one. 420
johnjohn2
Johnny Brown
  • 5763 Answers
  • Posted on Jan 27, 2010
SOURCE: right front tire
the next thing is to have the tire checked for a hop in it,meaning its not straight and round, start there.
Anonymous
  • 437 Answers
  • Posted on Feb 02, 2010
SOURCE: HELP!!! my lincoln is acting up!! once i hit
If you can absolutely verify that there are no loose components in the front end I would start looking at the tire for belt separation. This can be detected by rubbing your hand gently over the tread area. Feel for bumps,bulges, and irregularities. It should be fairly obvious.
You can also try putting the tire on a different location and see if the symptom moves to the new location.
A
Anonymous
  • Posted on Jun 27, 2011
SOURCE: Lincoln 2002 LS has low
The EGR Valve could be an issue
Almost certain you will have 1 or 2 bad cop
ignition coils a year,so misfire ,yes
Could be several other problems
Need the correct spark plugs,they are special
to the LS,anything will fit,but not work right
O2 Sensors have to get changed at 100,000 miles
MAF Sensor Cleaned
V6 or V8
V8 is a lot easier to work on & less issues
1helpful
Bouncing and front end vibration
warped rotors replace and then fix shocks since its what caused it in the first place also check ball joints and tie rod ends. see a typical vehicle use 70 % front brake and 30 % rear brake and when the shocks are bad a vehicle will use 80 to 90 % front brake which will cause the rotors to heat up over 400 degrees and then rapidly cooling causing them warp
Ford truck bounces hitting a bump
Have you cked the bushing lower and upper
Front end vibration
This is usually either wheel balance if you just feel the vibration in the steering wheel, or shock absorbers are worn if you can actually feel the front of the vehicle bouncing.
2helpful
Car makes a rattle noise on the littlest bump should I be concerned
Probably not, but we can't say until it is identified.
A very common cause of this in Camrys is that the rear suspension anti-sway bar retainer bushings become worn. See p 95
http://www.turboninjas.com/camry/sa.pdf
If you think the noise is more to the front then maybe a ball joint is worn, possibly the rack end ball joint or tie rod end.
Jack the front wheel up on each side in turn, grab the wheel at each side and shake it back and forth as hard as you can. If you hear or feel looseness, the problem is in the steering, as above.
Then shake the wheel while holding it at top and bottom. If you feel looseness then, the problem is in the front suspension joints somewhere.
Repeat this on the other front wheel. Let it down on the ground, then bounce each front corner up and down as hard as you can (you might have to have a second person with you doing this). If you hear a clunk or feel excessive bounciness, it is the shock absorber strut making noises. When bouncing like this, the car should resist, and not keep bouncing when you let go.
Knocking sound at steering wheel during turning of mistubishi adventure
It sounds like a ball joint is worn, possibly the rack end ball joint or tie rod end.
With the bumpy ride it could also be that the front shock absorber has failed.
Then shake the wheel while holding it at top and bottom. If you feel looseness then, the problem is in the front suspension wishbones.
Repeat this on the other front wheel. Let it down on the ground, then bounce each front corner up and down as hard as you can (you might have to have a second person with you doing this). If you hear a clunk or feel excessive bounciness, it is the shock absorber. When bouncing like this, the car should resist, and not keep bouncing when you let go.
Front end bouncing, I think it's the shocks
Is it a bounce or a vibration. If it where the struts you would only feel it when you went over a bump. To me it sounds like you have a tire issue. Either a tire is seperated or maybe out of balance. Let me know if you have any questions and I'll do my best to answer them. Thank you for using FixYa.com!
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
1helpful
Why would my truck bounce and shake while going down the road
when is this bouncing and shaking taking place? Is it doing it during stopping, is it coming from the rear end or the front? If it is bouncing more to the rear and it doesnt do it as much on braking as driving. Your problem will be rear shocks. Which aren't to bad to replace but if you do don't skimp or you will be in the same boat if you do.If the bouncing is coming from the front and not during braking then you r problem becomes a more broad subject. You could have front shock problem, tie rod problems, control arm ball joint problems. Many things. However if your problem is severe there are only 2 things that i would recommend checking, the tie rods and shocks. ! of those are bound to be the issue. Lastly if this is a problem when your braking mostly (I didnt get the feeling it was but wanted to cover incase) then your problem is going to be a break issue and you will need to replace your pads also check rotors and wheel bearings while your doing that. Any other questions just let me know and i will do my best to help. Hope I was of some help to you.
1helpful
From 30 mph plus the left front tire starts to "bounce". Tires have less than 15,000 miles on them. I have a 1993 Jeep Cherokee Country.
Tire bouncing (not shaking) is generally caused by a bad shock absorber. If you have 30k miles on them or you see any oil leaking form the top (but could be long gone), replace them. (front pair, rear pair, all four but never just one) If it's shaking, check ball joints, all other front end components and wheel balance.
HELP!!! my lincoln is acting up!! once i hit 60miles the right tire keept shaking or bouncing...not sure, i changed the pitman arm idler arm and the ball joints in the front of the car...by the way the...
At 45 MPH front end begins to almost bounce it shakes so hard.
The alinement is out. Check balljoint's and track-rod end's.Check these part's replace faulty part's and get it alined after.Cheer's
Top Lincoln Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Lincoln Expert? Answer questions, earn points and help others
