We just bought a Philips TV from a hotel. It did not come with a remote so we are using a Philips universal remote. We have it hooked up to basic cable. It is not getting all of the channels and the TV we had there before did. If you try to enter a channel it is not getting you get a message that says channel not available. Also I am not able to get the audio and video inputs to work. Do you have any suggestions?
In the menu usually a button on tv switch from antenna to cable or catv
if you remote won't work there are 7 or 8 different code choices go through them till it does work
most unversals need tv on and will turn off when code is right
also in menu is audio choices stereo on /off and so on play in there till you get it
Same problem plus there are no connections to hook up a vcr/dvd which the cable could have run through to get all the channels.
i have the same problem. bought universal remote and still cant program the tv...
