Nintendo Wii Console Logo
Posted on Dec 25, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Wii won't connect to Internet. Error code is 051330
  • yessum Dec 25, 2008
    iv the exact same problem with my wii when using wireless
Anonymous
Level 1:
  • Contributor 33 Answers
  • Posted on Mar 03, 2009
Anonymous
Contributor
Level 1:
Answers
33
Questions
0
Helped
17527
Points
37
When you are not able to connect with Internet from Your Wii, means there is something wrong with the settings. You may go to Wii Fix Guide and check out the guide available there, This DIY guide will show step by step pictures to fix the problems yourself without any technical knowledge.
Anonymous
Level 2:
  • Expert 231 Answers
  • Posted on Dec 25, 2008
Anonymous
Expert
Level 2:
Answers
231
Questions
Helped
180425
Points
717
Here's some troubleshooting suggestions for Wii Error 51330
=> http://www.wiierror.com/wii-error-51300.php
For other errors codes check the link below
=> http://www.wiierror.com/errors.php
3 Related Answers
Anonymous
  • 104 Answers
  • Posted on Jul 22, 2009
SOURCE: wii won,t connect error code 51330
Fiend your solution direct from nintendo. Here is your solution....
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
aqwtr-54
Anonymous
  • 82 Answers
  • Posted on May 14, 2011
SOURCE: bought a used wii and won't connect to the
This is not an error with Netflix, but rather it is an error with your wireless network set-up. I have seen many people have trouble connecting the Wii to their home networks, and it does not appear to be very user-friendly. Here is the page from Nintendo's official customer support center about your error code and how to fix it.
http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=51030&system=Wii&locale=en_US
Anonymous
  • 55 Answers
  • Posted on May 16, 2011
SOURCE: I can't get the Internet it says error code
I've had this same problem before. Try following the article below step by step. That's what got my Wii connected.
http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=51330&system=Wii&locale=en_US
Hope that helps.
Wii error code 204965
  1. Go into the Wii Menu (Wii icon on the main menu screen.
  2. Select "Wii Settings," then "Internet," and "Connection Settings."
  3. Erase your existing Internet Connection Settings and set up a new connection. (Click here for help)
  4. Once you have established and tested a successful connection test, try the connection to the Wii Shop again.
If you have verified that your Wii console's internet connection is working, then there could be a temporary issue with the Wii Shop Channel. Please wait awhile and your connection again.
If you have tried the above troubleshooting and are still receiving this error code, please call us 1-800-255-3700 so that they may assist you further.
What is error code 32007 my wii won't connect to
http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=32007&system=wii&locale=langYour Wii was disconnected from the internet during a system update.
5helpful
2answers
How do you set up Internet on the wii?
To access the internet with your wii console you'll need either a wireless router/gateway, or a wii wired LAN connector.
1. Power on your Wii console
2. Access the "Wii Setting" menu by selecting the circular wii icon in the bottom left of the screen and then choosing wii settings.
3. Use the arrow on the right of the screen to move to page two, then select "internet".
4. Select "Connection 1 ' None"
5. Choose "Wireless Connection" (assuming you have a wireless router), then select "Search for Access Point".
6. Wait for your wii to scan, then select your wireless network, and if prompted enter your wireless network password/key. Then click "OK".
You should now be able to connect to the internet. If your Wii runs a connection test and it proves unsuccessful it will display an error code. If you get Error Code 51330 or 52130 this means the password you entered does not match the password on the wireless network you are attempting to join. A list of all other error codes and what they mean can be found here: http://www.nintendo.com/consumer/systems/wii/en_na/onlineErrorCodes.jsp
Error # 051330 wath is it
This means that the WiFi password you are using is incorrect. Please verify that the WiFi password is correct. If it is, you may need to contact Nintendo.
My wii console will not connect to the Internet via my wireless router. It seems to recognize it because I can see it on the wireless options list but it will not connect. I'm trying to get my Netflix...
This issue is most often because of your Internet security.
You should log into your router using the default IP (consult the manual)
Locate the wireless security option
Now if you are using a 64 bit encryption the WEP key must be 10 characters long and consist of the number and letter A-F.
If you are using a 128 bit encryption then the WEP key must be 26 characters and consist of the number and letters A-F.
You can also try adjusting the channel your router is on, I suggest using channel 1 or 11.
hopefully this helps
I can't get the Internet it says error code 051330 unable to connect with server
Hope that helps.
Bought a used wii and won't connect to the internet to run netflicks getting error code 051030
Unable to connect to Net Flix. Error code 051330
This error code is given by the Wii when it cannot connect to the internet, try to test your internet connection. I'm assuming you are connecting through a Wii due to the error code. hope this helps.
I get error code 051330 when I try to connect to netflix
my friend too faced same kind of problem ............
his nintendo wii get stuck and never turns normal soon .....until its been restarted
if you are also facing exactly same problem
then dont worry
Go to this site and fix your problem by downloading repair guide
all the best
click here to download
1helpful
2answers
Wii shop channel won,t work
YOur internet isnt allowing the wii to access the shop...
Top Nintendo Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Aron
Sean Wright
Sean Wright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
