I would like to be able to use just one of the options on the control panel/touch pad. First I push the start button, and all the lights start to blink. I then press the "rinse and hold" button. This does not prompt the upper left light to turn red, like it says in the manual. Instead, all of the lights continue blinking, alternately. I can't get just the "rinse and hold" light to glow red, indicating this is the option I have chosen. This machine's control panel has never worked properly and it has been very frustrating, considering the cost. What is causing this problem and what are the solutions. We hardly ever use this ASKO because the control panel has never functioned like fit should.
SOURCE: Asko D1796 will not start properly
It sounds as if you may have A bad control board. It could be causing the heater element to come on when its not supposed to (usually a stuck relay) and not filling the machine with water. you could also have a bad control board AND a bad fill valve, as a stuck relay for the heater shouldn't affect the fill valve circuit. The bad news is that these asko control boards are $350 to $450 for just the part, the good news is that the control board is under a 5 year warranty (for only the part, not the labor to change it) as are the pump motors and any timers. Also, if you are just out of warranty, find your date of installation, as asko warranties start when you install it, not when you buy it (if you moved into the house and it was there when you moved in, and you are the first owner, submit a date of occupancy and that's when your warranty started)
SOURCE: Asko 1585 Dishwasher
do they flash lik all on one side then the other? Start a cycle, then open the door. Do the lights flash the same way when you open the door as when it stops? if soyou may have a door that needs to be adjusted so it closes better. when the cycle ends, is there any standing water in the bottom? if so you may have a poorly routed drain hose or a partial clog in it. Last, pull the bottom panels off and look inside the bottom of the dishwasher and see if there is standing water down there . If ther is you have aleak somewhere or a bad drain pump. You r only other choice is a bad pressure switch. If youve already adjusted the water fil to the proper level ( just up to the grey plastic housing that the lower wash arm sits on) tehre really aernt any more options. Hope this helps!
SOURCE: lights blinking
I have a 3122 and had a similar problem, Lights flashing, humming noise and me standing there scratching my head! I emptied all the water out of the filter basket and then tilted the machine backwards (only needed about 20 degrees) and then the rest of the water drained all over the floor... about 1/2 a liter. Now its all good! and the missus is nun the wiser!
SOURCE: asko 1805 - all idnicator lamps blinking
Searched some more on this site and found the following from a guest (thanks). It solved my problem, the base where all the electrics and plumbing is located had a pool of water. I had to pull the unit out as I could not access this area from the front.
This is a common problem with the Asko1805. The machine is equipped with overfill protection. Water has leaked through to the bottom pan and has triggered the overflow shutoff float. You must get the water out of the bottom of the dishwasher. Unscrew the kickplate and the metal cover to access the bottom of the machine where the pumps and motors reside. Use a sponge to slop up the water in the pan. Blow dry the bottom. The machine will reset itself as soon as the water is gone.
SOURCE: Lights on the Asko D1996 keep blinking
This depends on the blinking pattern. Of the eight lights on the panel, if the four on the left blink on and then the right four lights blink on as the left ones go off, and keep blinking back and forth, that just means the mode has been set and the Start button pressed. After closing the door it should just continue on wherever it is in the cycle. (This is normal operation).
If you hold down the Start button, this resets the dishwasher. If you then close the door, nothing will happen because it thinks it's done.
If the lights are blinking in a different pattern, such as they all blink on and off in unison, that indicates an error condition and needs to be diagnosed. If the pump is not running constantly, then at least it's not because water is leaking out somewhere.
The washer must be empty and the control must be in the OFF
state before pressing the touch-pad sequence to start the test.
Starting the Test Mode
? Close the door.
? Push CONTROL/ON (if present on this model).
? Select the DRAIN/SPIN cycle.
? Select NO SPIN by pressing the SPIN SPEED touch-pad.
? Push PREWASH OPTION four times within five seconds. (If
PREWASH OPTION is not present on this model, press EXTRA
RINSE four times within five seconds.) C:00 will light up on the
display.
If the Starting procedure fails, push the PAUSE/CANCEL touch-pad,
then repeat the starting procedure.
Test Program Control
In order to advance to the next step of the test procedure, push
PREWASH OPTION touch-pad two times. If PREWASH OPTION is not
present on this model, press EXTRA RINSE two times.
Read more: Whirlpool
Duet Washer 'Control Locked' - The Laundry Appliance Repair Forum -
Do-It-Yourself Appliance Repair Help - ApplianceGuru.com: The Samurai
Appliance Repair Forums http://applianceguru.com/forum2/1540.html#ixzz1AbBWB73c
Get appliance parts at http://parts.fixitnow.com
