Just got in my car today, i never turn off the radio and the display was blank and it does not turn on, so of course i can't use my phone either, grrrr.
Have you been able to check your connections from the unit to the antenna? If it was working before and then just quit I would start there first, a loose connection or frayed coaxial cable could be your problem, also if the antenna has moved it could be improperly grounded now and unable to receive also, you'll need to check the mounting of the antenna to make sure that it has come lose or built up corrsion. Roughly 80-90% of all radio problems/solutions are antenna/cable/connections based and rarely the radio itself.
SOURCE: 2000 Sonata - Radio quit working
you need to go to the Hyundai service center they can reset the radio I believe this is a security feature, you may be able to call the service center to find out the procedure to reset the radio, it is the original right ?
SOURCE: the car won't start; lights,
Check the starter and the starter relay or fuse. A client of mines car was doing the same thing, it ended up being two issues, the starter not working anymore, and a relay that was bad. If I am not mistaken everything should be labeled in the fuse box under the hood and will tell you where the fuse/ relay is for your vehicle
SOURCE: When I turn off the
is it a cavalier or sunfire in the door there is a dome light switch this allows you to listen to the radio or put thwindow up or down for 30 to 60 seconds sometimes the door switch shorts out on the drivers side you can test by taking the pass door switch and change for drivers door if not a short to body modual
SOURCE: pioneer car radio won't power on
Pulling the postive battery lead for you car battery, for a couple minutes, and then re-securing it again might help.
http://howtobyme.blogspot.com/2011/12/how-to-reset-radio-code-after-car.html
Can
car radio code block Passkey anti theft system ?
http://schematicsdiagram.blogspot.com/2011/12/can-car-radio-code-block-passkey-anti.html
How
to wire new car Radio?
http://schematicsdiagram.blogspot.com/2011/12/how-to-wire-new-radio-on-1990-toyota.html
Radio
Stereo Wiring Diagram?
http://schematicsdiagram.blogspot.com/2011/12/radio-stereo-wiring-diagram-for-1991.html
How to remove radio on Car models?
http://repairhelpcenter.blogspot.com/2011/11/how-to-remove-radio-on-acura-car-models.html
Where
is Radio Fuse located?
http://schematicsdiagram.blogspot.com/2011/12/where-is-radio-fuse-located-on-2007.html
After
Market Stereo wiring?
http://schematicsdiagram.blogspot.com/2011/12/after-market-stereo-wiring-for-1999.html
car
radio doesn't allow to switch to the XM Band to get the radio ID?
http://schematicsdiagram.blogspot.com/2012/01/chevy-car-radio-doesnt-allow-to-switch.html
No power to radio Scion Xb?
http://repairhelpcenter.blogspot.com/2012/01/no-power-to-radio-on-2005-toyota-scion.html
Radio has power but
no sound?
http://repairhelpcenter.blogspot.com/2012/01/lexus-rx330-radio-has-power-but-no.html
Radio goes ON and
OFF while driving?
http://technoanswers.blogspot.com/2012/01/radio-goes-on-and-off-while-driving.html
Town Car Radio stereo wiring?
http://technoanswers.blogspot.in/2012/02/lincoln-town-car-radio-stereo-wiring.html
Radio wiring
diagram for Car?
http://technoanswers.blogspot.in/2012/02/radio-wiring-diagram-for-1997-lincoln.html
How to remove cd
player from dash?
http://technoanswers.blogspot.in/2012/01/how-to-remove-cd-player-from-dash-on.html
This will help.
Thanks.
