When powering the projector, it seems working with green light on power and green on status. After about 1 or 2 min, the power become orange and blinking and the status become red and blinking as well. a short more while the power become orange and no blinking while the status keep on red and blinking none stop 6 cycles blinking. Pls help indicate what I should do. Thanks Veasna
SOURCE: Status indicator blinks RED, not starting.
There are different rates at which the status light will blink to indicate various errors. See manual (link below) page 49 http://www.support.nec-display.com/dl_service/data/user_manual/ENGLISH/VT37/vt37_manual_e.pdf
SOURCE: Lamp will not come on
try pressing and holding the enter button on the projector for about 30 seconds - this resets it. It worked for me!!
SOURCE: Status light blinking red
If it is a lamp error try this:
When the lamp exceeds 2100 hoursof service, the projector cannot turn on and the manu is not displayed. Do the following:
For VT670/VT470 Press the help button on the remote control for a minimum of ten seconds.
For VT570/VT47 Press and hold the power and the exit buttons on the remote control simultaneously for a minimum of ten seconds. When the lamp time clock is reset to zero, the lamp indicator goes out. Hope this helps! :]
SOURCE: Blinking status light
Replacing the lamp with an old one was helpful for me. Good news: the projector itself not faulty. Bad news: I have two projectors with the same issue at the same time (the lamps were replaced also at the same time) after only 400 hours of running.
SOURCE: I have replaced bulbs in 3 different types of NEC
I had the same issue, what I figured out was that I never removed the lamp door correctly, causing a small plastic piece to break off. To see if this is also your problem, inspect the back of the lamp door, top right corner, if it seems a rectangular plastic piece is missing, thats the problem. It presses in a small button nearby the lamp to let the projector know it's safe to power on.
I've attached an image to help out.
