Eaton Powerware 9135 UPS (700465446) UPS System Logo
Lise Houde Posted on Sep 05, 2012
Electrical requirement I need to know the voltage required and the Amp needed for this model, also the weight and BTU released
upstech
Level 1:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Contributor 38 Answers
  • Posted on Sep 12, 2012
upstech
Contributor
Level 1:
New Friend:
Cheetah:
Answers
38
Questions
0
Helped
21096
Points
48
If you locate a manual for this unit it shows it at the end of the installation manual with all the specs.
What is the electrical capacity of Maytag MDG9700BWW?
https://search.yahoo.com/search?fr=mcafee&type=E210US1494G0&p=the+electrical+capacity+of+Maytag+MDG9700BWW%3F
Then check related searches
MOTOR: 1/4HP,120 volt,60 Hz,single-phase,thermally protected against overload,auto-reset. EXHAUST:Use a minimum of 4"(10.2 cm) diameter rigid aluminum or galvanized steel duct. Never use plastic,nonmetal or combustible duct. HEAT SOURCE/ELECTRICAL REQUIREMENTS: Electric model- 5,300 watt nichrome helix coil; 240 volt,AC,60 Hz; 30 amp fuse. Gas model-Single port burner with automatic electric ignition; 22,000 BTU/hr. 15 amp fuse. Self-adjusting valve automatically compensates for variation in gas pressure. WEIGHTS (Crated/Uncrated):
3answers
HOW MANY AMPS DOES A RV 15,000 BTU AIR CONDITIONER USE AT START UP?
it draws locked rotor amps at power application. capacitors boost it quicker then you read it if all ok then runs at full load amps.
I'm replacing my gas furnace with a ac/heater unit that uses 240 voltage and want to know how many volts my furnace uses
If it's a 240 volt system, the maximum voltage required is 240 volts. Which would be what the furnace needs/uses to operate properly. But, I suspect what you really wanted to know is what is the amperage that's used/required. In most installations, it requires to 60 amp circuit breakers. However, yours may require less or more. Check the installation manual for more specific requirements.
My model # is 417.89875100 - i need to know the voltage it uses! 120? 220?
A 120-volt, 60-Hz., AC-only, 15- or 20-amp, fused electrical
supply is required
Here is a link for your owner's manual
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0409319.pdf
3answers
I'm going to Europe and wanted to know how to convert electricity so when I plug in my computer it won't fry the computer
This is a copy from the Radio Shack site. The quick answer is go to pretty much any electronic store or most travel stores and buy a Foreign Power Converter.
AC to AC Power Conversion (Foreign Voltage Converters) Purpose of Converter / Explanation of Operation AC-to-AC voltage converters, or travel converters, are designed to convert the voltage used in a foreign country to the voltage required for a particular AC device. These converters are either transformer-based or solid-state, and this affects what type of devices the converter can power. In addition to converting the power, you will often need to also use a plug adapter. Plug adapters are generally either built into the converter, or provided as separate parts. They are also sold separately, for use with multi-voltage devices that are designed to convert the power internally.
Selecting a Converter These are one of the more confusing of the power conversion devices. Because of the range of voltages, plug types and converter designs, many customers find that they need help determining exactly which converter they need. To aid in that process, we have put together a short worksheet to help you determine what type of converter is needed: We recommend that you print out thi sheet when taking a number of different devices to a different country.
First, you should determine the electrical requirements (voltage, frequency, and wattage) for the device(s) you will be taking with you. This information is generally on a label or embossed into the back or bottom of the device. Make a note of the voltage(s), frequency or frequencies, and the wattage indicated for each device.
  • The voltage may be given as either V, VAC or VDC. The standard voltage for US devices is 120 V. Devices that are designed to operate using different input voltages will be labeled, such as 110/120 V, or 120/240 V.
  • The frequency will be given in Hz. The standard frequency for US devices is 60 Hz. Devices that are designed to operate using different frequencies will be labeled, such as 50/60 Hz.
  • The wattage will be given in either watts (W) or volt-amps (VA). If the wattage is not listed on the device, you will need to contact the device's manufacturer for this information. If you have the maximum current consumption (in amps), you can calculate the wattage by multiplying the voltage (V) times the current consumption (A).
Next, you will need to know the electrical requirements for the country you are going to be visiting.
Next, you will need to compare your equipment requirements to the country's information to determine whether you need a Step-up or Step-down Voltage converter.
  • If your equipment accepts the voltage and frequency provided by the country you will be visiting, then only a Plug Adapter will be required.
  • If the voltage of the target country is higher than the voltage required by your device(s), you will need a Step-Up Voltage Converter.
  • If the voltage of the target country is lower than the voltage required by your device(s), you will need a Step-Down Voltage Converter.
Once you know what type of converter or adapter you need, consult our list of travel power conversion products to find one that meets your requirements.
Cautions
  • The AC outlet in many foreign bathrooms is for low-wattage devices only. To avoid damage to your converter and/or attached device, check with your host or hotel before powering a high-wattage device (such as a hair dryer) from this plug.
  • Do not use a voltage converter with electronic devices such as televisions, VCR's and computers unless the device indicates that it can handle both 50 Hz and 60 Hz.
  • Do not use heating appliances, such as hair dryers, irons and coffee-makers, on a transformer-based voltage converter.
  • Do not use non-heating electronic devices, such as calculators, electric razors and portable audio players, on solid-state voltage converter.
  • Do not use 110-120 VAC Surge protectors or Uninterruptible Power supplies on a 220-240 VAC system. Even with a step-down power converter, damage could occur as the two power systems are wired differently.
3helpful
3answers
What battery and where does it go for 35mm single lens reflex slr
Your camera uses 2 x CR123 batteries; they fit in a chamber on the underside of the camera beneath the right hand grip.
The camera is an autofocus fixed lens SLR and batteries are essential.
You can view a .pdf manual at the web address below: it's for an IS-20dlx but it's the same camera as the IS-200. Your model had different names depending upon where in the world it was sold. I recommend that you save the manual to your pc as there's no guarantee how long these resources will remain online for.
http://zuserver2.star.ucl.ac.uk/~rwesson/esif/om-sif/is-series/manuals/is_20_dlx.pdf
Please return the favour by rating my answer.
No wattage given with electrical requirements for gas cook top
A gas range requires minimal electric current. "Any ole" circuit will do.
Charlie
2answers
Is the Model #25HBA360A300 a 5 ton unit?
36k-car-ms Key Features AC Type: Split System Additional Features: Ductless Cooling Capacity: 36000 BTU/hr Electrical Requirements Voltage: 220It is a 3 ton aprox 550 sq feet per ton is required
Top Eaton Computers & Internet Experts
Ngoro
NOEL
NOEL
Are you an Eaton Computer and Internet Expert? Answer questions, earn points and help others
