The first time a connected the TV to my Macbook Pro, via HDMI and adapter, the tv went to static and then the connection was successful. I have since unplugged the cable, moved the TV to a different location, and have tried to reconnect. Unfortunately, only the Macbook Pro seems to respond (a temporary flashing blue screen), but the TV does not want to cooperate. Any suggestions? Is it possible to reset the TV settings? **The HDMI cable works when I connect it with to Windows supported laptops.
SOURCE: PS3 (Pal) won't connect to Sylvania HD TV
I just figured it out last night - if you have used your playstation on an hd tv previously, it is set at the highest resolution possible - 1080p. You need to take it back to that tv, and go to display settings on your tv. If you select HDMI as they type of connection you'd like to make, it asks you what resolution your tv supports. In your tv instruction guide, it should give you this information. Check mark all of the resolutions your tv supports, making sure not to confuse 1080i and 1080p. After doing this you can take it back to your other television and it should work.
SOURCE: Blurry picture sylvania ld320ssx LCD TV when connected to ps3
Must change the Signal Tuner board.U well have good video after that.Not than 100% ur LCD Black projection Screen is dead not worth repairing.
