Need help, my bottom freezer working fine, opened back panel in freezer and coils all frozen over, my main fridge is not cooling at all. Any suggestions to what is happening and what am I looking at costs estimates to repair either myself or technician.
First off unplug ref and melt the ice with a blow dryer.then check your defrost circuit,it is easier to check with the ice gone.
do you know how to use a multi meter?unplug the referidge and check to make sure there is not a open defrost thermostat and/or open heater. on the meter is will be around o ohms if it is infinite then that component is no good. the defost thermo is in line with the heater so unplug one side of the defrost tsat away from the heater and you can test both at 1 time let me know what you get for readings,
SOURCE: KENMORE MODEL 596 BOTTOM FREEZER, FRIDGE NOT COOLING
The freezer will stay cold because a small
amount of cold air will be forced through the frost but that will not
be enough to make it up to the refrigerator portion. You can defrost
the unit by removing the metal panel and allowing the frost to melt.
Careful use of a hairdryer can speed up this process. This will likely
be a temporary fix. The root cause of excessive frost can be caused by
a bad door seal or a defective defrost circuit.
First check that the door seal is good by closing the door on a dollar
bill at several points around the door, both on the freezer and
refidgerator door. If you can pull the bill out with no resistance, the
door is not making a good seal. Inspect the seal and make sure there
isn't anything stopping the door from closing such as food, or a shelf
not pushed in all the way.
If the door seal is good, the defrost system is likely defective. The
defrost system has three main parts, the defrost heater, thermostat,
and timer. None of these parts are particularly expensive, or difficult to replace you feel comfortable with repairing it yourself. If you can troubleshoot this by manually
starting the defrost cycle. Let me know if you would like this
procedure.
Looks like a possible defrost cycle failure I read this on another persons post, any suggestions on how to repair
Thanks will try it
I have same Problem? Freezer Works Fine but Fridge not cooling?
