Gone through settings cant find out how to turn off time/date stamp
Seeing the Date When Previewing images
Printing the Date on Pictures
SOURCE: Canon SD 1000 time and date stamp on downloaded photo
You can download the manual from the link below: http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=323&modelid=14901 From page 37 of the manual it looks like you can only select the time stamp in "postcard" mode. Also the date & time need to be set in the camera first. Please update the question & let us know if the information given was useful to you - Good Luck!
SOURCE: Putting the date/time stamp on my pictures
I have the same problem, if someone solved this, please let me know [email protected]
SOURCE: I AM TRYING TO SET THE DATE & TIME TO APPEAR ON MY PHOTOS.
you can only do date and time stamp under function button go to bottom where you can change size of pictures -go to right to W or wide-this is only setting you can do date time stamp on-when you change pic size and go back to menu you will see it highlighted and you can now turn it on-equals about a 2-3 megapixel size picture only-also just leave settings alone and have printer add it-date and time our always in pic data and most printers can add it
SOURCE: Setting date and time on the picture
OK, I FOUND SOME INFO ON A WEBSITE THAT I'M GOING TO HOTLINK FOR YOU. SEEMS LIKE THE ONLY WAY YOU CAN DATE/TIME STAMP A PHOTO IS TO HAVE THE CAMERA IN THE POSTCARD MODE. YOU CAN READ ABOUT THIS IN THE WEBSITE I'VE LINKED FOR YOU. HOPE THIS SOLVES YOUR QUESTION, AND IF YOU NEED MORE HELP, REPLY TO:ARCLIGHT1217. IF THIS HELPS, PLEASE REMEMBER TO RATE THIS SOLUTION. THANKS!
http://www.imaging-resource.com/PRODS/SD750/SD750A3.HTM
GOOD LUCK!
SOURCE: cannot turn date stamp on in menu settings.
Date stamp is only possible when you set the resolution (picture size) at "Postcard 1600x1200" option, if the date stamp is set to "Date & Time" or "Date" option
