SOURCE: Unable to access DLink WBR 2310 Configuration page
Reset the router first, press the reset pinhole on the back for 10 seconds using a paper clip, don't press it too much or it will mess up the settings of the router. then try to access again the configuration page.
SOURCE: dlink wbr-2310 router no wireless working
you have to change your channelk type in your wi fi router.
For that access your router with following link
http://192.168.1.1 or
http://192.168.0.1
if you have belkin router
http://192.168.2.1
type user name as "admin" and password is "admin" or blank or "password"
then go to wi fi ->advanced setup chang channel type 4 ,6 ,11
change chanel type 1 by 1 and check signal strength.
everyt time save settings and restart both computer and router after save settings.
Thanks for using fixya.
Please rate this solution if it helps.
SOURCE: VPN Using XP Servers and D-Link WBR-2310
I had exactly the same problem. The solution is to set up pptp as a virtual server pointing to the lan ip of the server. Port forwarding only forwards the port but not the GRE protocol (pptp passthrough)
SOURCE: windows 7 not connecting with wbr-2310
You will need to check the wireless settings of the router
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
Click here for step by step instructions
SOURCE: D-link WBR-2310 has serious drop out problems
https://spreadsheets.google.com/viewform?formkey=dGNHT2tRS1RscnI1ZV96THpzRWgxVVE6MQ
