Cameras Logo
Devon Cournoyer Posted on Aug 16, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Vivitar itwist610dvr won't save files to my sd card
I just opened the camera, and popped in a 4gb sd card. Now whenever I take a picture or video and go to view it in playback mode, I get a black screen that says "no file". Help?
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Cameras Master 102,366 Answers
  • Posted on Aug 16, 2012
Cameras Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10444211
Points
622693
Unless you've found a VERY rare 4GB SD card, your 4GB card is actually an SDHC card. The 610 will not work with SDHC cards. Try using an SD card, 2GB and smaller.
5 Related Answers
Anonymous
  • Posted on Nov 22, 2006
SOURCE: Blank Screen and faulty shutter blades
I found out the hard way that you should never use alkaline batteries in a Digital Camera. I thought my camera had a fundamental flaw (power kept going off whenever I tried to take a photo or record a video and the shutter blades half closed) even though it was only 2 months old. I nearly wrote it off but all along the problem was that I was using alkaline batteries, which incidentally were enclosed with the camera in the box!! Once I switched to NiMH (Nickel) batteries the camera worked fine and the fault completely vanished! These NiMH batteries are avaiable in most electrical shops i.e currys/comet in the UK. They must be charged before use. They are more expensive than alkaline batteries (£8-£9 for 4) but as they are rechargable they last a long time.
Anonymous
  • 172 Answers
  • Posted on May 16, 2008
SOURCE: Panasonic Lumix DMC-FZ20 SD Card Reading Issue
Plug you camera into USB. Go to My Computer and find a drive device named External Drive or USB Storage etc. Click on this and you should see a folder named DCIM (digital camera EXIF standard Digital Camera IMage folder. This is your cameras memory card.
Click on this and find a subfolder(s) named according to manufacture. For Panasonic it would be 100_PANA or maybe 101_PANA. These are you picture folders. Click on one to find pictures. Drag and Drop folder to computer to download them.
Anonymous
  • Posted on Aug 19, 2008
SOURCE: Pictures Readable on Camera, but NOT on computer
I found the solution to the problem. Connect the camera with the cord supplied. Do not open Finepix. Open Photoshop if you have it and go to file>import>via f31 or f30 and choose the pictures you want to import. Done !!!!!
zohail
Shoaib Rais
  • 1223 Answers
  • Posted on May 05, 2009
SOURCE: No view on screen of what is showing in front of lens. Menu and playback shows but nothing when i turn to camera mode or video mode.help!
CCD Failure !
Lucky u can get it repaired Free just call Sony in ur region see link
http://esupport.sony.com/US/perl/news-item.pl?mdl=DSCT1&news_id=161
Anonymous
  • Posted on Jun 28, 2010
SOURCE: cannot open or copy - parameter is incorrect?
..wel, i solved mine.. im copying music files into a memory card like micro SD.. when im copying music.. it says.. cannot copy file.. the parameter is incorrect... then go into My Computer then Right Click the external hrd drive(micro SD),, then go to properties....then tools.. then click the Check now.. - it will check for some errors and automatically fix the errors.. :D thats it..
How do i change the storage function of a vivicam s529
What happens when you try to format the card in the camera?
2answers
SD Card Problems with Vivitar Vivicam 5118!
What size is the memory card. If it's larger than 4GB then it won't work in the 5118.
Try using another card. Don't format it in your computer but do format it in the camera before trying to take pictures.
Cannot open files on SD, and there are corrupt files
Did you connect this SD card to your friend's computer before you connected it to your computer. If so your friends computer may have corrupted the SD memory card.
Try this recovery program.
Recuva (pronounced"recover") is a freeware Windows utility to restore files that havebeen accidentally deleted from your computer. This includes files emptied fromthe Recycle bin as well as images and other files that have been deleted byuser error from digital camera memory cards or MP3 players. It will even bringback files that have been deleted from your iPod, or by bugs, crashes andviruses!
  • Simple to use interface - just click 'Scan' and choose the files you want to recover
  • Easy to use filter for results based on file name/type
  • Simple Windows like interface with List and Tree view
  • Can be run from a USB thumb drive
  • Restores all types of files, office documents, images, video, music, email, anything.
  • Supports FAT12, FAT16, FAT32, exFAT, NTFS, NTFS5 , NTFS + EFS file systems
  • Restores files from removable media (SmartMedia, Secure Digital, MemoryStick, Digital cameras, Floppy disks, Jazz Disks, Sony Memory Sticks, Compact Flash cards, Smart Media Cards, Secure Digital Cards, etc.)
  • Restores files from external ZIP drives, Firewire and USB Hard drives
  • It's fast, tiny and takes seconds to run!
Go to these WEB sites to down Recuvahttp://download.cnet.com/Recuva/3000-2242_4-10753287.htmlwww.filehippo.com/download_recuva
1helpful
Downloading from the CD provided with the Digital video camcorder is unsuccessful
You don't need the Vivitar software.The best way to download videos from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy videos from the card to the computer's hard drive, the same way you copy any other files.
I recently bought the vivitar 7024 and bought an sd card lexar multi use 4 gb. For some reason when I take photos and try to look at the pics it says no file exist. But when I take the sd card out and I...
Apparently, you have pics on the camera's internal memory. Your card won't work until those pics are gone. Here's how...with no card in the camera, go into the menu and find "format" and follow the on-screen instructions to erase the internal memory. Then, insert your card and it should work.
Itwist610DVR, i do not have a manual, how do I put batteries in, and the SD card?
You can download the manual from the manufacturer's web site at
http://www.vivitar.com/files_products/440/DVR_610_Camera_Manual.pdf
8helpful
5answers
How do you restored formatted pictures back to the camera
I have had success with this photo recovery program... Download the program
http://www.asoftech.com/apr/
You have to use a card reader either on your computer or an external USB card reader. Put the card in the card reader, open the recovery program, then select the drive where files are deleted, then press "Start" and wait for it to do it's magic.
1helpful
2answers
I have a vivitar video recorder model no 840 xhd. can you tell me what memory card to get for it. the hand book says I need a standard SD card upto 32GB.but most card have other numbers or letters after...
It can use MMC cards or SD cards or SDHC cards up to 8GB in size.
SD cards top out at 2GB. 4GB and larger cards are technically SDHC (Secure Digital High Capacity) cards.
Top Cameras Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Camera Expert? Answer questions, earn points and help others
