20 Most Recent Vivitar ViviCam 7024 Digital Camera Questions & Answers
How do I lighten the pictures?
Check your camera settings: White balance should be set to auto, ISO should be set to auto, flash should be set to auto, scene should be set to auto, Exposure Compensation should be set at 0. If images are still too dark change ISO setting to 200. If that doesn't work change to 400. If that still doesn't work change exposure compensation to +1. If your photos are still too dark your camera is defective.
11/11/2014 5:50:43 AM • Vivitar ViviCam... • Answered on Nov 11, 2014
How do I lighten the pictures? They are too dark.
And you did put the camera in automatic? and not in a scene mode, or something like that? I don't know if your camera has a setting like A, S, M or P, but you should not use these settings, unless you know what you want to achieve with that setting.
11/10/2014 9:22:54 PM • Vivitar ViviCam... • Answered on Nov 10, 2014
My Vivicam is always showing low battery, even I replaced the batteries as per specification.
i am not sure if you are using recharchable batteries but if you are that is the problem those go out really fast in these types of cameras try using fresh batteries.
10/13/2013 8:13:11 PM • Vivitar ViviCam... • Answered on Oct 13, 2013
My vivitar vivicam 7024 keeps saying memory card full when there is a brand new memory card in it whats going on?
maybe its not you memory card try using the usb and hook it up to your computer to see what photos you have taken or you can use the playback mode to view them and see if you took photos on accident this happend to me but i found out it left my finger on the shutter button and took lots of pics or if you have young ones around you ask if they mess with your camera
10/13/2013 8:08:17 PM • Vivitar ViviCam... • Answered on Oct 13, 2013
5answers
How do you restored formatted
I have had success with this photo recovery program... Download the program http://www.asoftech.com/apr/You have to use a card reader either on your computer or an external USB card reader. Put the card in the card reader, open the recovery program, then select the drive where files are deleted, then press "Start" and wait for it to do it's magic.
5/22/2013 6:03:09 AM • Vivitar ViviCam... • Answered on May 22, 2013
Download
You don't need any special software.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program such as Picasa.
4/27/2013 7:52:25 PM • Vivitar ViviCam... • Answered on Apr 27, 2013
I don't no how 2 upload pictures from my camera
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
4/30/2012 10:42:22 PM • Vivitar ViviCam... • Answered on Apr 30, 2012
I need to download a
You may download a copy of the manual here.
4/3/2012 6:35:07 PM • Vivitar ViviCam... • Answered on Apr 03, 2012
The disk that came with
You don't need the Vivitar software.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa.
4/3/2012 6:31:35 PM • Vivitar ViviCam... • Answered on Apr 03, 2012
My flash isnt working on
There's a slide switch on the end of the camera. Slide it from the flower to the mountain.
3/31/2012 7:02:02 AM • Vivitar ViviCam... • Answered on Mar 31, 2012
My camera wont let me
You need to switch out of the macro mode. There's a slide switch on the end of the camera. Slide it from the flower to the mountain.
3/31/2012 7:01:30 AM • Vivitar ViviCam... • Answered on Mar 31, 2012
Well u see I have no sound so when i upload my
The 7024 is designed primarily as a still camera, with limited video features grafted on. As such it captures images not sounds. You can add a soundtrack using video editing software on a computer, but you cannot record one on the camera.
3/31/2012 7:00:32 AM • Vivitar ViviCam... • Answered on Mar 31, 2012
Saying no flash in Macro
There's a slide switch on the end of the camera, near the USB socket. Slide it from the flower to the mountain.
3/31/2012 6:57:34 AM • Vivitar ViviCam... • Answered on Mar 31, 2012
I lost the disc to
You don't need any software to use your camera. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa.
3/31/2012 6:54:01 AM • Vivitar ViviCam... • Answered on Mar 31, 2012
The flash does not come on my camera it says macro
There's a slide switch on the left end of the camera, near the USB jack. Slide it away from the flower symbol toward the mountain symbol.
3/31/2012 6:47:10 AM • Vivitar ViviCam... • Answered on Mar 31, 2012
Vivitar ViviCam 7024 Digital Camera Logo
55 questions posted
Top Vivitar Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
View Most Popular
ViviCam Vivitar
  • ViviCam Vivitar
Most Popular Question
lighten pictures
  • Cameras
