Night Owl Security Night Owl Poseidon-DVR Network DVR - 8-CH, H.264, Smartphone Logo
Posted on Aug 11, 2012
Forgot password for poseidon dvr
I forgot my password and I am locked out. is there an administrator password or a way to reset to factory default (no password)?
I got locked out of my kurio
If the tablet is connected to the internet, tap on forgot password or pattern then enter gmail account to receive an email with the correct password/pattern you set.
Below are steps to recover from being locked out. The first is the most extreme. The second is less extreme. And the third is probably the preferred method.
Firs, t the extreme reset. You lose your data but it returns it to factory default condition, i. e. right out of the box.
Kurio Extreme 2 Factory Reset
Secondly, the soft reset.
Kurio How to Perform Soft Reset
Thirdly, a Kurio password reset:
Kurio Password Reset Kurio 4S Kurio 7S Kurio 10S
I have a Haier tablet Computer, Model X111, which I forgot the password. I would like to know what are the keys to press to reset to factory partition..
Do a hard reset on it and you can rebootif you wanna or you can go to administrator on cp and settings and go from there
How do I recover my lock screen password for my tabeo tablet
Not possible to recover your password just factory reset back to when new! Press power for 30 seconds then press power and volume+ buttons together until reset screen comes on then move to factory reset option using volume buttons and select using power button!
1helpful
2answers
How to reset a zeki tablet password
Hello there,
From the Zeki website it says do this.
If you have set the screen lock to a password or pin code, and have forgotten the code; you will need to reset you tablet to factory default setting.
  1. Make sure your tablet has a full charge
  2. Press and hold the Volume - button and tap the Reset button
    (The reset button is located between the HDMI and USB ports)
  3. Continue holding the Volume - button until the boot screen appears
  4. Release the Volume - button
  5. Use the volume controls to navigate to "Wipe data/Factory reset"
  6. Press the power button to select
  7. Navigate to "Delete all user date"
  8. Press the power button to select
Your table will take several minutes to reboot to a factory default setting.
Hop this helps you friend. :)
How do i unlock my screen i forgot my password
Note: Your Kindle Fire lock screen password or PIN is different from your Amazon account password.
Reset Your Kindle Fire Reset your Kindle Fire if you forgot your lock screen PIN or your parental controls password and need to regain access.
If you have any content not saved in your Kindle Library in the Cloud, be sure to transfer that content from your device to your computer via USB.
Important: Resetting your Kindle Fire will remove all content downloaded to it. Any content you purchased from Amazon is saved to your Kindle Library in the Cloud and will remain in the Cloud. You can download that content again if you register your Kindle Fire to your account again.
  1. From Home, swipe down from the top of the screen, and then tap More.
  2. Tap Device.
  3. Tap Reset to Factory Defaults, and then tap Erase Everything.
Your Kindle Fire will restart.
To use your Kindle Fire again, you'll need to connect wirelessly and register your Kindle Fire.
2answers
Forgot my wifi password
Hi there, you can reset your wifi device by holding Down something on the litle whole on the site, and if you tell me wich model i can tell you more about resetting
Jul 29, 2014 • Nabi 2
1helpful
Viewsonic7Dprotablet screen lock password forget
If you forgot your password you need reset your tablet to factory default to make it useful again.
2helpful
Need to reset kindle fire
To reset a Kindle Fire to factory default, tap "Settings" (the gear-shaped icon near the upper-right corner of the screen, then tap "More". Scroll down and tap "Device", then scroll down and tap "Reset to FActory Defaults".
3answers
Forgot password on the acer netbook with windows7
Have you forgot windows 7 password?
Now, we'd recommend you a professional Windows password recovery software- Windows Password Reset as your reference.
As an easy method to reset Windows 7 password , there are only four steps as follow:
Step1: Download Windows Password Reset Deluxe and install it.
Step2: Burn the ISO image file onto a USB flash drive.
Step3: Boot up your Windows 7 PC by the bootable burned USB in minutes.
Step4: Remove the forgot Windows 7 password on the operation interface and logon PC without password.
Top Night Owl Security Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Night Owl Security Tablet and eReader Expert? Answer questions, earn points and help others
