20 Most Recent
Digital Products International Zeki 7 Questions & Answers
How to reset a zeki tablet password
Hello there,
From the Zeki website it says do this.
If you have set the screen lock to a password or pin code, and have forgotten the code; you will need to reset you tablet to factory default setting.
- Make sure your tablet has a full charge
- Press and hold the Volume - button and tap the Reset button
(The reset button is located between the HDMI and USB ports)
- Continue holding the Volume - button until the boot screen appears
- Release the Volume - button
- Use the volume controls to navigate to "Wipe data/Factory reset"
- Press the power button to select
- Navigate to "Delete all user date"
Your table will take several minutes to reboot to a factory default setting.
Hop this helps you friend. :)
Googleaccountrecovery
quite often the user name is the E-Mail address of the account holder, and if you have that then password recovery can usually be sent to you via E-Mail
How to install rom on Onn 100011886 tablet go edition.
"rom"? What exactly are you trying to do? Are you referring to ROM as part of the tablet's memory? If yes, you probably will not be able to do it. ROM is a memory chip built onto the circuit board itself inside the tablet. You would need to completely dismantle the tablet to do it. Most tablets are not built to be taken apart for repairs.
4/13/2024 11:56:23 PM •
Tablets &...
Answered
on Apr 13, 2024
