Polycom VSX 7000 Video Conference Logo
Posted on Dec 17, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I forgot the password of polycom VSX 7000 system. now how can i reset the password? pls help ASAP.
Cloudbooks
Level 2:
Mentor:
An expert who has written 3 tips or uploaded 2 video tips.
  • Expert 163 Answers
  • Posted on Dec 17, 2008
Cloudbooks
Expert
Level 2:
Mentor:
Answers
163
Questions
0
Helped
111155
Points
477
The default is Admin with password of the 14-digit serial number
Anonymous
Level 2:
  • Expert 84 Answers
Anonymous
Expert
Level 2:
Answers
84
Questions
0
Helped
44378
Points
192
More than likely you'll have to flash the codec to factory default and then the password should be the codec serial number....
I'm trying to connect a polycom vsx 700 to this conference room. Same unit is able to connect to local scopia xt5000 with no trouble. If dialing 135.11.119.48 it times out without connecting to an
hello
This is not a dialing but trying to connect to the IP address setup in the system. Start editing the IP address giving the one that you would have already allocated to the device in the Router (i.e. 192.168.1.99) and then reboot it. It should connect then automatically.
Best regards
No AGC output,not normal colour
Pls can you ellaborate more on the problem...
How to reset the password of polycom hdx 7000
You can use the hardware restore button on the Polycom HDX system to reset
the system in one of these ways:
• Restoring configuration-Restores the configuration, which resets most
system settings to default values.
• Factory restore-Completely erases the system and restores it to the
software version and default configuration stored in its factory partition.
If you follow this procedure while a USB storage device is connected, the
system restores from the USB device instead of the system's factory
partition.
The restore button is on the front of the Polycom HDX 9000 series system, as
shown in the following figure.
The restore button is on the front of the Polycom HDX 8000 series, Polycom
HDX 7000 series, and Polycom HDX 4000 systems, as shown in the following
figure.
The restore button is on the left side of the Polycom HDX 4500 system, behind
a wire mesh screen, as shown in the following figure.
Use a paperclip to press the restore button through the wire mesh covering
that side of the system. to reset the HDX Series system we can press the restore button over 15 second.
My VSX 7000S does not recognize the microphone. It is connected to VSX\r\ncamera by the brown RJ11 cable with ferrite end to the camera but no sound is picked up and system status indicates "no...
You need to go into the audio settings via
Admin Settings
Audio Settings
and make sure Enable Polycom Microphone is checked off.
Reboot and see if your microphone is recognized.
4helpful
2answers
How to reset VSX 8000 to factory default - Forgot the password
RTFM!!!
section 8, page 4
System -> Diagnostics -> Reset system
you will need serial number for this
good luck.
Polycom VSX 7000 will not turn on
Hopefully the problem was resolved. Call Polycom to see if it under warranty. Call me at 415.659-8178 if it is not. Maybe I can help. David
Polycom vsx 7000
no the power supply is propreitory( has multiple voltages) & is not advisable, u could blow up ur expensive confeencing equipemt.polycom has designed it in that manner!!
11helpful
4answers
Forgot the polycom VSX 7000 password - how to reset
The polycom didn't allow for numbers, only letters.....
How do I do password recovery in this case?
8helpful
2answers
Factory reset
put a paperclip in the front just below power button and turn unit on. this will factory reset it.
Top Polycom Lands Phones Experts
k24674
Are you a Polycom Lands Phone Expert? Answer questions, earn points and help others
