I need a workshop manual for a 1995 Honda 90 HP outboard motor any ideas on where to get one? Online preferable. Im working on the gearbox at present. So even the section on how to align and set up the gear change, etc etc I have a schematic diagram from a spare parts manual
SOURCE: Yamaha outboard motor manual
You got it :
http://www.yamaha-motor.com/outboard/service/viewmanuals/outboard_manuals.aspx
here !
SOURCE: need oil change in water
If its a 2 stroke, there is no oil to change, if its a 4 stroke, you can pump the oil out with a small diameter tube pump.Depending on the motor, you can get it through the dipstick or the fill opening. If you need to change the gear oil, there is no way to change it while in the water. Stop by a marine supply store and get some oil absorbsion pads (diapers) in case you happen to spill any oil into the water
SOURCE: Hi,I am looking for an online manual for an 85 hp mercury outboar
i have service manual for MERCURY IN LINE 75-150 HP-it covers all however my scanner printer down at present so unable to scan to lappy to be able to email at prez-hopefully this week-waiting on my computer man!
SOURCE: Hi i am looking for a repair manual, online, free
Mel's Marine Service Inc. stocks those repair manuals and will ship them. I believe they run about $50.00. There phone number is 541-689-0136. They are open from 8-5 pacific time mon-fri and 9-2 on saturday.
SOURCE: Gear shifter locked in forward gear
If the gear lever is loose,it's the gear connection rod that you disconnect to do a g/box drop.If its not loose, drop the g/box off the leg and the first thing you find might be the problem.A loose bolt,a jammed shifter.It will probably be a connection problem than a g/box problemHope this helps
