SOURCE: How to set up password for voicemail/how to set up new mailbox
By default, a Panasonic TVA voice mail system can have a password set. It could be 3 plus the extension number, but it doesn't matter. You can clear it by logging into mailbox 999 and going to options 6 1 3 which will be the mailbox password menu. Select the lady's extension and follow the instructions to confirm password deletion.
Now she can call voice mail from her extension and set a new password.
This also works for a TVS system.
Carl
SOURCE: No one can leave messages as my mailbox is full -
Call the voice mail system from your phone (usually ext 165), put your password in, and start retrieving messages. Use a lot of 3's (delete) and it will get it down. IIRC you are only allowed about 100 or so but it is set by VM class of service.
Carl
SOURCE: Mailbox recieves messages but is not saving them (KX-T7630)
This sometimes happens on my phone. The only way I have found to clear this is to leave a voice-mail. Check your messages delete the test message and your system should clear itself out.
I think what happens is it gets stuck thinking there is a message. So when you clear the new message it then realizes there is no more messages. I know this works on my phone and could be the same for yours.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
SOURCE: Hi, I need help on
TVA and TVS systems have master passwords that the installer has. If you lost the password to 999, then your installer can probably come out and reset them. If you have lost the master password, Panasonic can restore that, but it's not easy.
If you happen to have the password for 998 and 999, you get there by pressing #6 *99x at the login. Put in your password and IIRC admin is option 5 or 6 in 999.
Carl
