How do I 3- way conference call with the Panasonic KX-TGA542M Cordless Phone?
Most phones have a Flash button - I also don't know how to switch back and forth between the call I am on and a call coming in with this particular model.
Thank you!
Tammra Green
One of the two "soft buttons" at the top of the keypad (first row of keys under the handset's display) should read Flash when you are on a call. Hit that button, you'll hear the line tone, dial the number and wait for the other person to answer. Hit Flash again and they should be joined together. If not, you may need to subscribe to Call Waiting/3-way Calling through your telephone company.
Check to see if your Panasonic phone has a flash key feature. If it does, press the flash key down and wait until you hear the confirmation tone. If the Panasonic phone you're using does not have a flash key, hold down the the hook switch for half a second, then release. Dial the number of the third person in your conference call. If you're inviting someone in-house to be a part of your conference call, dial their extension number instead. If you're dialing an outside line you may need to dial 9 before dialing the number.
Wait for the new addition to the conference call to answer and then press the Flash key again. Wait an additional two or three seconds before pressing the number three on your telephone keypad. Start your conference call. Once you've pressed the flash key followed by the number 3, as in Step 4, your conference call is established. If you wish to add additional participants simply repeat Steps 3 and 4.
Regards
