To turn off the Pelican Sabrelite 2000 flashlight, you will need to locate the switch or button on the flashlight that controls the power.
On most models of the Pelican Sabrelite 2000, the power switch is located on the tail cap of the flashlight, near the base. To turn off the flashlight, you will need to press and hold the power switch for a few seconds until the light turns off.
If you are unable to locate the power switch or if the flashlight is not turning off as expected, you may need to refer to the owner's manual for your specific model of Pelican Sabrelite 2000. The manual should provide information on the location and operation of the power switch and any other controls on the flashlight.
If you are unable to find the owner's manual or if you are still having trouble turning off the flashlight, you may need to seek further assistance from the manufacturer or a technical support professional. They will be able to provide you with more information on how to operate your specific model of Pelican Sabrelite 2000.
The pelican doesn't upscale. If you have yellow white red connecting something to the pelican, you need yellow white red connecting the pelican to the TV, not just component cables.
There should be several USB ports on your 360. There should be one in the back and two in the front lower part of the console. It is hidden beneath a small flap you can push in with your fingers and slide the cable into the usb
Check to verify that your batteries are installed correctly. - Check to verify that the power is on. Check to verify that the signal LED is blinking
If this does not solve the problem, do the following:
1. Make sure your Xbox is turned off. 2. Remove the battery lid and place 2 AA batteries into the Blade 2.4 Street Wireless Controller. Make sure the batteries are inserted as shown in the battery compartment. 3. Insert the receiver into your Xbox controller slot of your choice and power up the controller FIRST, then your Xbox. 4. Press the Connect button on the receiver once. Your signal LED light will begin to flash slowly. 5. Press the Back button on your controller. This will program the receiver to connect to the controller each time it is uses. 6. Turn on your Xbox and insert a game.
