20 Most Recent
Pelican PL-2050 XBOX EDGE 2.4 GHZ WIRELESS CONTROLLER (PELPL2050) Questions & Answers
My network is using a linksys wireless G router
hira895
In regards to your wireless connection issue with your XBOX 360 do you have the wireless adaper connected to the XBOX. Note most XBOX 360's do not have a built in wireless adapter, some of the Elites do but most do not.
Hope this helps
Issken
I have a old xbox system and my wireless
Check to verify that your batteries are installed correctly.
- Check to verify that the power is on. Check to verify that the signal LED is blinking
If this does not solve the problem, do the following:
1. Make sure your Xbox is turned off.
2. Remove the battery lid and place 2 AA batteries into the Blade 2.4 Street Wireless Controller. Make sure the batteries are inserted as shown in the battery compartment.
3. Insert the receiver into your Xbox controller slot of your choice and power up the controller FIRST, then your Xbox.
4. Press the Connect button on the receiver once. Your signal LED light will begin to flash slowly.
5. Press the Back button on your controller. This will program the receiver to connect to the controller each time it is uses.
6. Turn on your Xbox and insert a game.
Wireless not working
Run the network tests from within the 360 menus - looking especially at the result for network address translation (NAT). If this is either limited or fail, you will need to change your router for one which is compatible with xbox live. Try xbox.com to work out which routers are recommended.
As far as your router kicking him when you connected your pc, then you must have altered the access permissions of the router maybe by accident.
If all else fails, turn off the pc, router, modem and 360. Find the reset button on your router and press/hold this for at least five seconds. Turn on the modem, then the router. Let that settle for a minute, then connect and setup 360 and laptop.
How to turn off pelican sabrelite 2000
To turn off the Pelican Sabrelite 2000 flashlight, you will need to locate the switch or button on the flashlight that controls the power.
On most models of the Pelican Sabrelite 2000, the power switch is located on the tail cap of the flashlight, near the base. To turn off the flashlight, you will need to press and hold the power switch for a few seconds until the light turns off.
If you are unable to locate the power switch or if the flashlight is not turning off as expected, you may need to refer to the owner's manual for your specific model of Pelican Sabrelite 2000. The manual should provide information on the location and operation of the power switch and any other controls on the flashlight.
If you are unable to find the owner's manual or if you are still having trouble turning off the flashlight, you may need to seek further assistance from the manufacturer or a technical support professional. They will be able to provide you with more information on how to operate your specific model of Pelican Sabrelite 2000.
