SOURCE: i have a marshall avt 100 which was working fine
This is a problem I would recommend for a qualified Marshall amp service person to look at. Worst case scenario is that somehow the speaker out put transformer or the power transformer burned out. They aside from output tubes are the most expensive parts to replace. Add shop labor on top. Ask for an estimate first. Consider how much a new amp will cost and then decide. I would personally go for the repair myself.
Testimonial: "thanks for the help about my avt i will get it mended i think as it isnt a bad amp, cheers"
SOURCE: blown fuse
Continued replacement of fuses without fixing the reason for them blowing MAY be doing additional damage to components in the unit.
It needs to go to a repair shop. It is likely there is damage in the power supply section or that of the power amplifier section.
SOURCE: Marshall AVT 100 dfx doesn;t work
junn561,
Thank you for asking me directly to help you with your problem. However, either the question you are asking is not within my area of expertise (I am an automotive repair technician), or the question is incomplete and does not contain enough information for me to help you.
