SOURCE: restore factory settings to acer aspire laptop
Restore and recovery
The restore and recovery features allow you to restore or recover the system
from a factory default image, from a user created image, or from previously
created CD and DVD backups. You can also reinstall applications and drivers for
your Acer system.
1 Press <Alt> + <F10> or select Acer eRecovery Management from the
Empowering Technology toolbar to start Acer eRecovery Management.
2 Switch to the restore and recovery page by selecting the Restore button.
3 Select the backup point you would like to restore from. You can also
choose to recover the system from a factory default image, recover from a
previously created CD/DVD or reinstall applications and drivers.
4 Follow the instructions on screen to complete the process
SOURCE: I need windows 7 driver to 7 Acer aspire 9500
Now there's an Update from Windows Update, it's listed in the optional Updates
SOURCE: my acer aspire 5742-7653 internal microphone is
go to the sound mixer(double click on speaker mark on the task bar). and then click on option, and then properties.you can see dialog box with recording and playback settings.
first mark on playback , and check activate the mic on that, if not put the tick on selection box.
then mark on recording. check the mic activation same as that. then click ok. you can see recording mixer.
OK now check have an advance controller button near the mic controller . if not click on option, and check have a tick with the advance controller. if not put the tick in frount of addvance controller. now already you in recording mixer. now you can see that button.
after that, click on "select" check box with the mic and increase the level to top. then click on "advance" controller, and put the tick on mic 1 boost. then close all windows and check the mic,
using via some recording software (like as windows sound recorder ), or activate the mic for working with speakers via put the tick on the mic tab on playback mixer. ( when that can hear like some siren noise , pull down the mic level to control that)
SOURCE: HOW TO USE BLUETOOTH ON
My daughter has a similar model in this series, and hers does not have Bluetooth capability. What is very misleading (and, in my opinion, bordering on false
advertising) is that there is a Bluetooth switch on the unit that doesn't actually
do anything since the card is not installed. Bluetooth is listed as one of those "varies by model" features, so yours may not have it either. (I only found that out when I opened her laptop to see why the Bluetooth wasn't turning on.)
Most likely, the only way you'll get Bluetooth working on your model is to buy a USB Bluetooth adapter (a "dongle") and plug it in. Unless yours does in fact have Bluetooth installed and it the card doesn't work, in which case you'll need to have the computer serviced.
SOURCE: does acer aspire 5742 have wi-fi
Actually, Wi-Fi is another term for Wireless Network. Well, the answer to you question is Yes, it is a wi-fi ready machine. You don't need any additional hardware to access a Wi-Fi network, in other words, it is a wi-fi certified machine. Hope this helps.
Good Luck.
Thanks for using FixYa.
