Roland Spd-S Sampling Percussion Pad System Logo
Posted on Dec 13, 2008
Bought used Roland SPD-11 with extra drum pads. Not getting much/any sound from these external pads. Triggers on main SPD-11 unit, ok. Also, would like original user manual. Downloadable version anywhere??
Anonymous
Level 1:
Problem Solver:
  • Contributor 8 Answers
  • Posted on Dec 31, 2008
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
8
Questions
Helped
13538
Points
9
  • Anonymous Dec 31, 2008
    try coping the link below:
    ftp://ftp.roland.co.uk/productsupport/Manuals/
Can you please tell me the best amp that I can use to hook up a Roland SPD 30, I'm looking for one to get volume. ( loud ).
Hi, With my sound engineers hat on I would use a small PA. mixer, amp and speakers!!!!
For quality you need a full, flat frequency range system with good headroom.
I assume this is for your own listening, when using an acoustic kit?
There are one box solutions.
  1. Drum amps. Like a monitor wedge with an amp, Roland do a PM-10, Various other makes are available.
  2. General purpose powered wedge.
  3. Keyboard Amp, these are full range and available in various sizes.
  4. Bass amp with high frequency driver (tweeter), not the best but will have good bottom end.
  5. Powered or active speaker, much like a powered wedge, but a different shape, needs an input volume control.
All these systems need to have large bass units, 10 inch minimum, and will be in mono. Two will give you stereo,
How loud depends primarily on the sensitivity of the speaker. But manufactures insist on selling things by power. Worth looking this up.
At a couple of feet away, 20 watts should do it, with high sensitivity speakers, more likely you find most things as above start at about 70 Watts.
Good luck, I hope I have widened you choices a bit.
All the best, Chris the Fader.
Display on Spd-S
this could be fixed at a cost of nearly 100$
What does the polarity + - switch do on Roland PD7 & KD7 pads do? also is it possible to purchase replacement internal triggers for these & how do the thin plastic actual trigger parts work...
The polarity switch selects whether the pressure causes a positive or negative electrical spike. This can affect whether your drum MODULE fires on the hit or when the hit is lifted.
Thin plastic triggers are an electret plastic and have piezoelectric properties.when their shape is changed by pressure, etc.
7helpful
3answers
How to reset my roland spd-s
You can reset Roland SPD-S by using Roland SPD-S utility CD supplied with product.
If you can't locate (or lost) the CD that is included with the SPD-S which contains the factory data, you can download the file here:
http://www.rolandus.com/products/pro...37&ParentId=61
Click the downloads tab and select the "SPD-S Factory Restore Data" (PC or Mac) link.
I think it helps.
If you have any query regarding this issue leae a feedback we were happy to assist you.
Have a Nice Day!
1helpful
Roland td-5 shows analog test error
You must get a Roland or Boss B.R.A. adapter, I just got mine from Sweetwater for 27.00 or something like that, fixed the problem completely, no 3rd party adapters, it's rigged so you must buy theirs, If you use a 3rd party adapter, it will fire up, and run "analog" test error there after. I hope this helps somebody. Peace Out!!
Need User Manual for SPD-11
3answers
Roland Spd-s pad #1 change to different patches when hit
I think there is an option in the setup menu that makes the pad do this.... i remember reading it in the manual. sorry cant help more than that...
2answers
Pad sound not geting
the trigger may have gone bad - I'm actually on line now looking for replacement parts.
open up the unit and that part looks like a coin, attached to a wire.
Top Roland Audio Players & Recorders Experts
 Grubhead
Grubhead
Arnie Burke
Arnie Burke
ADMIN Andrew
ADMIN Andrew
Are you a Roland Audio Player and Recorder Expert? Answer questions, earn points and help others
