20 Most Recent
Roland Pd 8 Dual Trigger Pad Questions & Answers
Hey, I have had used
Check the connections on the undersides of the pads--they sometimes get loose as the vibrations rattle them around. Tighten the nuts that hold the pads inputs in place and reinsert the cables until they sort of "click." If that doesn't work, it might be the cables themselves, so try switching them with one you know is currently working. It'll change which sound is triggered where, but you'll know it's just the cables that need to be replaced, not the pads.
The cable assigned to my
You may have a bad solder joint where the jack for the snare trigger input is soldered to the circuit board. You will have to open the case and have a look. Make a note of how many screws and where they go etc. If you have a digital camera, take pictures as you go. We have a TD3 and it has two circuit boards one on top of the other.
Is there a rim shot trigger ?
Yes there is a rim shot trigger. Your electronic generator has to be set correctely to use it. Refer to the manual. Usually the trigger is carried on the same cable and has a "different waveform characteristic" which your Roland sound generator recognizes and reacts to.
Screen on roland td7 lights
Look for a contrast control for the display... often a small tweek shaft that comes out of the case. This is only if the thing operates but has no display.
Rim sensor not functioning
Here is a link to some great help:http://www.instructables.com/id/DIY-Electronic-Drums/ You can use Radio Shack piezo transducers as replacement triggers if you need to. They are much cheaper but take a little careful work. Hope this helps.
What does the polarity + - switch do on Roland PD7
The polarity switch selects whether the pressure causes a positive or negative electrical spike. This can affect whether your drum MODULE fires on the hit or when the hit is lifted.
Thin plastic triggers are an electret plastic and have piezoelectric properties.when their shape is changed by pressure, etc.
Hi. Can I use the second pedal on my Roland BK5 to scale up the key one semitone at a time?
Yes, you can use the second pedal on a Roland BK-5 keyboard to transpose the key of the music that you are playing up or down by a semitone at a time. To do this, you will need to press and hold the second pedal while playing the keyboard. You can also use the transpose function in the settings menu of the BK-5 to adjust the key of the music that you are playing by a specific number of semitones.
1/5/2023 4:04:49 PM •
Roland Music
Answered
on Jan 05, 2023
I need a circuit diagram for a Roland MA-15D speaker please?
It's a Chinese made Roland and no service information is available as when a fault is found the main board is replaced, eliminating the need for service information.
I would check that it is a stereo out jack and not mono. If it is a stereo out, check that both input phonos work. If they do, replace the faulty socket or damaged pcboard.
11/17/2022 6:14:26 PM •
Roland Music
Answered
on Nov 17, 2022
