if you are using CHUNGHOP RM-306E this would be applicable for all brands of TV..
1) Turn on the TV
2) Press S button (top left corner) until red light on
3) Press Green button (power button top - right corner)
4) press volume + button (blue at the middle on the left) until the volume signal display on the TV
5) press S button again
Now you are set..
Test the remote function it should be working now.. if not repeat the steps above until you got it working..
Good luck..
If you wish to get more details, surf the following
link. There are over two thousand and
four hundred posts. All are related to
television and other domestic electronic equipment service help. You can get a solution there. Type in the
brand name to your device to its search box, can be located at the top right of
the display window. It will make search
easy. More than Nine Lakh viewers
cannot be wrong.http://electronicshelponline.blogspot.com/
Hi to all all the above solution to pairing your phone to parrot system don't. Work toyed them all
But this will work first
Turn your Bluetooth off on. Your phone
Now turn on the parrot sys go to settings
Go to pair devices were the old phones are still in the memory. You need to go to each one press the green button roll the menu button down
Till it shows you delete this phone press the green button
Do this till all old phone that were in the memo are gone then and only then do you turn on your phone Bluetooth and it will find the parrot sys it will ask you for a code
Enter 1234 and the phone is paired this will work as I did it this way to day
No green and red button pressed together or all three will etheir
So save your time and do it this way many thanks ;);)
Generally If System Is Unused For A Certain Amount Of Time Time It Will Go Into Was Is Called Sleep Mode. Also Make Sure You Locate Your Fan And Make Sure Its Able To Pull In Air For Ventilation Which Keeps The System Cooled Down And Wont Allow System To Get Hot
Unfortunately you have the red light of death (RLOD). Which means your graphics card has overheated. Repairable, but prob won't last. Mine didn't. I'm on my 3rd PS3, thankfully the slimline models don't suffer this problem.
Hope this helps.
LJ
On the HT1000, there is an A, B, C toggle switch just under the On/OFF/Volume control knob.
When set to A, the radio is IN the scan mode.
When set to B it is NOT in the scan mode.
When switched to C, it is in the scan program mode. There is a green
button on the left side above the PTT switch. When you set it to C, you
switch the CHANNEL SELECT knob to the desired freq you want to add to
the scan list. When there, you push the green button. ONE push gives
you a red indicator light on the top of the radio. A 2nd push gives you
a GREEN light displayed. A 3rd push gives you NOTHING lit up.
The 1st push (RED light) means you have selected THIS freq as your PRIORITY channel of your scan list when scanning.
The 2nd push (GREEN light) means it is just IN the list, not as a priority channel.
NO light means it is NOT entered into the scan list.
Once you have your list set up, simply flip the A,B,C switch back up to A and you're scanning what you selected.
HOWEVER All of the above is dependent on whether or not the
ORIGINAL setup programming from the factory set the radio up for these
features to work. If it WASN'T set up that way, you'll have to have it
reprogrammed to activate the buttons and the toggle switch for those
features to work.
There are two tabs that hold the top of the lighthouse on; push in gently just above one of the tabs, and it should release the top of the lighthouse. The red and green covers just pop off.
puzzle 130:Assuming on a chess board 8x8 that each square is numbered 1-64 top left to right.Place a queen on each of these squares 3,13,18,32,33,47,52 and 62 bobs yer uncle
