20 Most Recent Sony Bravia KDL-40V4100 40 in. LCD HDTV Questions & Answers
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here. .
Sony Bravia... | Answered on Oct 20, 2016
Fault at its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
Sony Bravia... | Answered on Dec 11, 2015
T'Con board fault. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
In some models of LCD TVS; the backlight inverter and its T'Con board will be a part of the panel itself, and will be a built-in type inside the LCD panel. If so, they can't be replaced. In this case; a panel replacement is the only repair. For some other models, the backlight inverter section circuit will be a part of the main power supply regulator [SMPS]. To such sets, the power supply section circuit too should be troubles hooted. Contact any service technician. The circuit will differ with models and versions.
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Sony Bravia... | Answered on Feb 23, 2015
Sony Bravia KDL-40V4100 models have a problem with the screen going blank, faded or washed out ( negative ghosting) . It is caused by a bad chip on the T-con board. A replacement chip is available from shopjimmy.com (Sony 55.40T02.C08 T-Con Board Component Repair Kit) for $14.95- If your not an excellent solderer, send your board to them for a repair $69.95.
Sony Bravia... | Answered on Dec 17, 2014
T'Con board fault. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Sony Bravia... | Answered on Sep 19, 2014
These blinks [flashes] are fault indication (Error Codes).From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it.This will make repair easy.These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times.Count it carefully.If you wish to get some details, check the site linked here.It has details about blinking codes, and fault locating, to many popular brand TVs and other devices.Viewing it in "Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given.
Gopakumar Gopalan Google
Sony Bravia... | Answered on Feb 24, 2014
Power supply regulator board fault. These blinks [flashes] are fault indication. You can get an idea about the faulty stage circuit inside the TV, by the number of these blinks. Count it carefully, by switching it ON and OFF, more than 2 times at least, so that, you can make sure about the number of these blinks. If you wish to get more details, check the site linked here. Surf the site in "MOSAIC" view.
Sony Bravia... | Answered on Jan 28, 2014
Service manuals are in PDF, and cannot send it by this window. To get some information, http://electronicshelponline.blogspot.com/Pull up older posts.
Sony Bravia... | Answered on Dec 03, 2013
Try to reset the tv first from set up menu. then check the brightness control working properly.
Sony Bravia... | Answered on Nov 24, 2013
Sony Bravia KDL-40V4100 40 in. LCD HDTV Logo
80 questions posted
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
BRAVIA Sony
  • BRAVIA Sony
Most Popular Question
sony kdl 40v4100 when turned off
  • Televison & Video
