I have had this golf cart for over 3 years and this is the first time this has started to happen. I have purchased 2 20 amp fuses on line to replace, and have now replaced it twice.
This is not a car question, but generally speaking a fuse blows when the current in the circuit exceeds the limit of the fuse.
I would look at the amp draw of the motor if that is what runs on that circuit and also the connections. It could be that the motor brushes are wearing out and the motor is pulling too much current.
I'm somewhat lost on your description - - you say it is a 60amp fuseable link but you bought 20 amp fuses. Are you dealing with two different circuits ?
SOURCE: Wire between alternator and solenoid/battery is burnt out!
you need to trace the hole line there is a opening or wire is touching some where if none of this is the case wires are crossed up some where which will burn up everything on the line
SOURCE: 04 Tahoe blowing fusible link in fuse box for starter
HI...
ON the fuse box cover.
IS there a especification for the funtion of the fuse. or the number of the location of the fuse.
If you can give me, I can try help you. as more I can.
Thank you for use fixya.
SOURCE: no spark no fuel no start! replaced and checked
funny thing is I have a 2002 GTI with the exact same problem. have spent the last three days at work trying to figure things out.. best of luckn email me if you figure anything out. [email protected]
SOURCE: I need a wiring diagram for a 1986 ezgo golf cart,
use this link http://www.vintagegolfcartparts.com/cgi-bin/gallery/gallery.cgi?func=show&file=200332&Category=100013&Page=1
SOURCE: Rear axle fluid for 1983 ez go electric golf cart?
Regular 90 weight gear oil. Fill until it reaches the fill hole.
Hank, The cart man
