Dell Inspiron 1545 Notebook Logo
Posted on Jul 23, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My inspiron 1545 wont turn on battery and charger are fine can anyone tell what could be wrong
Anonymous
Level 3:
  • Dell Master 32,281 Answers
  • Posted on Jul 24, 2012
Anonymous
Dell Master
Level 3:
Answers
32281
Questions
Helped
7913602
Points
102259
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
5 Related Answers
Anonymous
  • 55 Answers
  • Posted on Nov 25, 2008
SOURCE: DELL INSPIRON 6400 BATTERY CHARGE PROBLEM
The battery has 5 small dots in it. Those are there for no reason. Those are actually LED lights. There's a button you can press. If we number the lights 1-2-3-4-5 with 1 being closest to the button, check the lights when you press the button. If 1-3-5 are lit, that means that you have a dead battery and needs to be replaced. Other than that, you're battery might still be working but nearing the end of its life. Goto support.dell.com -> drivers and downloads -> enter your service tag or system type -> download Dell Quickset. Once Quickset is installed, it will diagnose your battery automatically and let you know if your battery already needs a replacement. It is just sad that batteries are covered with a separate 1-year warranty only. You can also go to www.dellbatteryprogram.com and check if your battery was part of the Dell Battery Recall Program.
Anonymous
  • 3940 Answers
  • Posted on Feb 01, 2009
SOURCE: dell inspiron 1501 work fine turn off last night now wont turn on
You mentioned trying a different battery, try a different AC adapter.
When plugging in the ac adapter to the wall, see if the POWER LED comes on on the adapter, then when you connect it to the computer, see if the LED stays on.
If the issue occurs with both AC adapters (No battery installed) then the motherboard has failed. If one ac adapter works but the other doesn't then the adapter is bad
Anonymous
  • 175 Answers
  • Posted on Aug 04, 2009
SOURCE: i have a dell inspiron 1525 and it wont charge
If possible could you check output voltage of the charger with a multimeter? If you can get output voltage, then might be something wrong with laptop battery charging circuit. Contact Laptop Repairing Engineer.
Regards;
Hassan
Anonymous
  • 76 Answers
  • Posted on Oct 04, 2009
SOURCE: Dell Inspiron 1545 AC Adapter error message
-check the system battery information and charger information of the computer; restart the computer, while the computer is booting up, press F2 repeatedly; check "battery info"
-if it stated ac adapter = unknown device ; update the BIOS (-visit support.dell.com
NOTE:other computers may have different BIOS, if it is not the same you may have to consult manufacturer
-click on drivers and downloads
-click or choose by service tag
-download the BIOS and install it on the computer)
-check information after updating; if same message AC adapter = unknown device; call manufaturer for a replacement AC adapter, if status has changed it is a battery problem or motherboard, contact manufacturer to test battery
Anonymous
  • 2567 Answers
  • Posted on Sep 21, 2010
SOURCE: dell inspiron 1545 wont turn
Start taking your laptop apart piece by piece and test it after each removed component:
1. Remove the hard drive and test the laptop.
2. Remove the DVD drive and test the laptop.
3. Remove the wireless card and test the laptop.
4. Unplug the display panel from the motherboard/video card and test the laptop.
etc....
Continue taking it apart until you have only three major components connected: motherboard (with video card), processor, and memory. If you still experience the same problem, most likely it's bad motherboard.
By the way, before you start, try reconnecting the memory module. If you have two modules installed, try removing them one by one and test the laptop with each one separately.
1helpful
New battery and charger wont charge over 45%
The battery needs to be calibrated from the setup. I this doesn't work, then ask for change of battery
1helpful
My inspiron 1545 come on some time but not all the time what is wrong and how can i fix it ? it tries to boot up and when it dose it is fine but it wont come on
Im very sorry to hear that, please follow these simple steps for you to be able to isolate the exact problem.
1. Removed the battery.
2. Connect the laptop directly to the power outlet without using the battery just for the meantime.
3. Turn on the laptop. If the laptop is able to power on, that means that the AC adapter is working fine as well as the DC port. If the laptop is not able to turn on, it maybe the AC adapter itself or the DC port.
4. Try to use another AC adapter if possible, make sure that that AC adapter is working fine. If the laptop is still not turning on, the problem is with the DC port itself. In that case, you will need to replaced the Motherboard itself.
Hope this will help...Thank you for using Fixya...
Dell inspiron 1545 laptop has went through 5 chargers they work for 6 months and then say does not not charging does not recognize battery
This is similar problem I had on my laptop.
Its a problem with the battery not the Charger If computer is in Warranty you get it from Dell or buy a new battery
4helpful
2answers
I have a dell inspiron 1545. i have the charger plugged in but a red light is flashin on my laptop. this light then turns white and immediately red again.if i remove the charger the laptop just switches...
take the battery out and try powering on your computer only with the power cord plugged in
if the computer turns on then
this is the problem with the battery
you need to replace the battery
Thank you
1helpful
My Inspiron 1545 turns off when I unplug it from adapter, and when plugged in, the power light on front flashes four times orange and one time white repeatedly.
Does the battery for dell inspiron 1545 plug in. It maybe because the battery pack is too hot ,you can turn off the laptop,let the pc notebook and the laptop battery both cooled down.Then try turn on it to see. If still happen to the matter,it must because the wrong turn off did harm to your Inspiron 1545 laptop adapter.
My dell inspiron 1545 says plugged in but not charging
its the charger if the charger is longer before trie changing the battery or if that doesnt work u have to replace the motherboard (around 155.00 GBP)
My dell 1545 inspiron wont operate on the battery works fine on charger and battery icon shows 100% and charging but as soon as power removed laptop immediately powers down. physically measured battery...
I think that if it's 100% it should say that it's fully charged.There could be something wrong there.
My computer blinks with a red icon on the printer saying that the it's recommended the battery be replaced when the battery goes bad. It shows 100% charge as well.
I just got a 9 cell battery off of Ebay for my Acer Aspire that lasts 3 or 4 hours and is a little big, but fits the contacts and locks on.
3helpful
2answers
Dell laptop wont turn on
first change the battery then check the charger if the problem still occurs then it will be hardware problem, it is better to check it on the dealer if ur laptop is under the warranty.
2helpful
2answers
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
