HTC Desire S Cell Phone Logo
Posted on Jul 13, 2012
Was having problems with mini SD card in my HTC Desire S as it kept unmounting. Following advice from work colleagues and forums, I transferred all my stored memory from the mini SD card to my laptop
Was having problems with mini SD card in my HTC Desire S as it kept unmounting. Following advice from work colleagues and forums, I transferred all my stored memory from the mini SD card to my laptop. I then reformatted the mini SD card and reloaded all the files back onto it. I have since discovered that nearly all my photo's and videos (Around 440) have come back as thumbnails and this is also true of the copy made onto my laptop before reformatting. Have I lost these photos for good? or is there a way of restoring them??? Help!
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Aug 01, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
421
Points
I don't think you lost your pictures. Same thing happened to my phone. I brought it to the HTC Service Center and they upgraded the software. I suggest you take it to the nearest HTC Service Center so the problem can be resolved.
1 Related Answer
Anonymous
  • 9 Answers
  • Posted on Mar 28, 2012
SOURCE: will unmounting sd card erase photos on htc hero
Never
tip
How to copy iTunes AAC(M4P) WMA Music to HTC Evo 4g, HTC Desire, HTC Incredibe
Quoted from: Transfer iTunes to HTC Evo 4g
Q: "I have some AAC Music I bought from iTunes but when I put some of them on my HTC Evo SD card it says this Music cannot be played. Is there any way around this? Or an app I can get?"
A: "Here is the thing, Apple's iTunes AAC (m4p) music and other protected WMA music with DRM protection can't freely transfer or playback on other devices, If you want to play iTunes AAC music on your HTC EVO 4G, you just need to use some DRM Converter software to convert the iTunes music to HTC EVO 4G compatible format."
This Text will show you how to remove DRM from iTunes music, Convert DRMed iTunes AAC(M4P) M4A WMA to MP3 and transfer to HTC EVO 4g, HTC Desire, HTC Incredible
Step1. Free download Daniusoft DRM Converter, install and luanch it, the default settings work well with your PC, you don't need to make anymore configeration.
Step2. When come to the main interface, click "Add" to import DRM license protected music video files from iTunes or common files you want to convert.(you can right click on a song in iTunes, select "Get Info", and it will tell you where on your computer that file is located)
Step3. Choose the target output format you need.( HTC Touch Evo 4g/Desire/Incredible compatible audio fomats: MP3, WMA, AAC ,etc and Video fomats: MP4)
If you want to customize output setting, just Click "Settings", there will be a pop up window displaying the output settings parameter, such as Formats, resolution, frame rate, bit rate etc.
Step4. Convert iTunes to HTC Evo 4g or HTC Desire/Incredible
After finishing all the necessary steps, you can click "Start" to start converting your file. When the conversion progress reaches 100%, the DRM Copyright protection on iTunes is removed and conversion is easily done!
Step 5. Transfer converted iTunes Music to HTC Evo 4g, HTC Desire/Incredible
After you get the output music files, you can connect your HTC EVO 4G or HTC Desire/Incredible to your computer via USB, select Disk Drive when your phone asks. Then go to My Computer and click on your phone. it should appear as an external hard drive. There should already be a music folder with the preloaded songs there. You can now just copy the music of your iTunes into that folder and your HTC EVO 4G or HTC Desire/Incredible will now have all your music in the Music app directly.
remove drm from wmv ' iplayer ripper ' remove drm from itunes 10 ' itunes to droid ' Transfer itunes music to htc evo 4g ' wmv to ipod touch 4g ' drm removal ' convert m4p to mp3 ' amazon video on demand ipad ' remove drm from itunes ' remove drm from nokia music store ' m4v to droid ' iTunes to galaxy s tab
on Oct 23, 2010 • Cell Phones
Htc rhyme wont recognize sd card
Try the SD card in your computer, see if it is corrupted. If not, copy the files off of it and then re-format it - then try it in your phone.
If that does not work, try a fresh SD card in the phone (maybe borrow one?)
If that fails too, it may well be that the internal SD card reader in the phone has gone bad.
Dec 30, 2013 • HTC Rhyme
2helpful
How do i download my photos from htc desire hd to my laptop
You can copy your music, photos, and other files to your phone's storage card.
  1. Connect your phone to your computer using the supplied USB cable.
  2. On your phone's Connect to PC screen, tap Disk drive, and then tap Done. On your computer, the connected phone is recognized as a removable disk.
  3. Navigate to the removable disk and open it.
  4. Do one of the following:
    • Copy the files from the computer to the phone's storage card's root folder.
    • Copy the files from the phone's storage card to a folder in your computer.
  5. After copying the files, unmount the removable disk (that is, the connected phone) as required by your computer's operating system to safely remove your phone.
1helpful
2answers
Can i use a Micro sd hc memory card in an HTC desire?
Yes! an HTC Desire is compatible with microSD™ memory card (SD 2.0 compatible)
How do i upload pics from my htc hero to my computer
Its in the manual. If you don't have one download it from HTC. It answers a lot of questions. You'll also might need to download HTC sync from their website as well. But you'll need to plug the phone into a usb port with the cable that came with the phone. When the computer sees the phone then you have to unmount the sd card. There will be a notice in the notifications bar on the phone. Just click unmount. it should show up as a drive on the computer. just remember MOUNT the sd card again BEFORE you unplug it from the computer. You could trash the sd card!!
13helpful
2answers
I receive the following message when I try to take a picture using the HTC hero. "unable to save file to sd card due to insufficient file permissions" david
i was having the same problem and i went to settings then to sd card and clicked on Unmount SD card and i took out the sd card, then placed it back into my phone and now i can take pictures and video :]
1helpful
Sd card, or device error when copying music files
If you are trying to play the file then it will be unmounted as it needs to disconnect from the pc to do that you could try copying them in batches if that doesnt work it may be a USB driver fault in which case i would reccomend reinstalling the G1 driver.
Top HTC Cell Phones Experts
NOEL
NOEL
john h
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
