Hi i have a 1995 mercedes s500 the car is flat and i cant gt the boot open to get to the battery and jump start it is there another way i can jump start the car from the engine thank you
I'm pretty sure they are specific to your car you must call dealership with year make model and vin # and you will have to prove ownership some how title or registration and driver's license
My father in-law had this same problem what we were able to do was go through the back seat. if you remove the back seat it will allow access to the trunk
SOURCE: replacing the battery in a 2001 mercedes benz
Battery base has a device that clamps the battery on a step/notch on the side. Use a ratchet with an extension to loosen. Once it is loose you can remove the battery.
SOURCE: 1998 s500 mercedes benz trunk will not open
Try the fuse first. If you have done this than the problem could be in the actuator on the trunk latch. Poss loose/bad wire or faulty unit? I hope this helps!
SOURCE: Mercedes-Benz 230clk coupe 1998 with dead battery
I had same problem with my 2002 CLK430. Dead battery with car locked. You can't open doors with the mechanical key (inside remote key), as windows need power to slide down slightly to allow clearance, so you can't access the hood release. The answer is to insert the mechanical key in the key hole for the trunk (boot). It will only go in one way, with the slightly larger grip part down. I found it easiest to turn with a pair of flat nosed pliers. Turn counterclockwise to the left to to the 11 o'clock position. Then push the release in and the trunk will open. Battery is located in the right rear quarter under the flooring panel that also covers spare tire. Hook up charger or jumper cables and power will come back on, as will alarm. To disable, just push the unlock button on the remote key. You should be good to go from here!
used plug and go charger to jump start car but doesn't work did for 1 hour
