SOURCE: Replacement remote for bell expressvu
Here is the link to pdf document: http://www.highspeedsat.com/pdf/satellite-tv/expressvu/remote.pdf
SOURCE: Codes to program Innovage Products Jumbo Universtal Remote
H have the jumbo universal remote from innovage pruducts. can you e-mail me all the codes? thanj you. [email protected]
SOURCE: lost directions for universal remote control
sent to me by nextech....
Save Code list for future reference. Refer to the setup procedure below and look up the 4 digit code for your brand of TV, VCR, etc., from the list below.
1519001B, 1519002B, 1519003B, 1519006, 1519007 CL
Refer to the Owner’s Manual for your remote for more information.
Direct Code Entry
1.
Press and hold the
SETUP button until the
red indicator stays on,
then release the SETUP
button.
2.
Press and release
the desired Mode button
(TV, VCR, etc.). The red
indicator blinks, then stays
lit.
3. Enter the 4 digit code from
the code tables. Note: after
a valid code entry, the red
indicator turns off. For
an invalid code, the red
indicator flashes.
4. With your device on,
press CHANNEL UP. If
the device responds, no
further programming is
required. Note: If some
buttons do not operate
your device, try one of
the other codes for your
brand.
Note, when all codes have
been searched the red
indicator flashes rapidly for
3 seconds.
Code Search
If after trying “Direct Code
Entry” your device does not
respond, or if your brand is
not listed, try doing a search
of the code library for your
code by following the steps
to the right.
1. Manually turn on the
device (TV, VCR, etc.) to
be controlled.
2. Press and hold the
button.
3. Press and release the
desired Mode button
indicator blinks once, then
stays on.
4. Press the CHANNEL UP
button repeatedly (up to
300 times) until the device
to be controlled changes
channel. The red indicator
blinks, then stays lit.
5. Press and release MUTE
to install the code. The
indicator light goes off.
Most users will want to
store VCR codes under the
VCR button, Cable codes
under CBL, etc. If you want
to store a VCR code under
CBL, etc., first follow the
procedure for Direct Code
Entry and press CBL in step
2 of Direct Code Entry, then
enter ANY VCR code in
step 3 of Direct Code Entry.
Then follow the steps above
for Code Search.
Direct Code Entry
1.
Press and hold the
button.
2.
Press and release
lit.
indicator flashes.
brand.
3 seconds.
Code Search
to the right.
be controlled.
button.
desired Mode button
stays on.
for Code Search.
answer found at [email protected]
SOURCE: need remote code for programming a bell expressvu receiver
Here for the Jensen remote just click below;
Here is link to the manual:
http://www.remotecodelist.com/remotes/jensen/JR300C.pdf
Here is some helpful information I found:
Without the code on JER-323:
1.Manually turn on the component you want the remote to control.
2. Press the device button, example:( TV) and the (power button) for 3 seconds until the (on/off button stays lit).
3. Once the (on/off) button is lit, press the (on/off) button until the unit (the TV or unit you are trying to control.) turns off.
4. When the code is located, press the (stop) button at the bottom to save the code.
Here are some codes I found for the Jensen 323:
GE VCR: 2000, 2013, 2021, 2022, 2053, 2087, 2089, 2091, 2115, 2120
Motorola Cable Box: 5000, 5003, 5046, 5047, 5052
Mitsubishi TV 0093, 0150, 0178, 0019
JVC VCR 0067, 0041, 0008
JVC DVD 0558, 0623
Hope it may help you;
Regards,
VOTIT
