ERROR CODE 95-751
SOURCE: 91-215 error code
91-215 is "communication error between system control and keyboard." could be a loose cable, open fuse, capacitor problem, etc.
SOURCE: 09-824 error
09-824 error code indicates a problem with the threading motor. check to make sure noting is obstructing the threading ring.
SOURCE: Our sony dsr 45 is giving us a C:31:41 Error code
error cause by drum head, u can try fix by ur self, open the compart then open the black drumhead cap,u can see to screw on the upper head open,then u can see rubber pick it up clean the rubber and the con inside outside head, try again if doesn't work u can change the drum head
