20 Most Recent
Sony DSR-1500 Mini DV VCR Questions & Answers
Error 95-744 on DSR1500 AP sony
Main code 95 : Digital signal process system error and communication error with ICs
7 : STANDBY-OFF mode
4 : Capstan motor/FG
4 : FG cannot be detected.
91-215 error code
91-215 is "communication error between system control and keyboard." could be a loose cable, open fuse, capacitor problem, etc.
Error 09 - 824
The error 09-824 is meaning you have problem with threading motor. Please check it out , repair or replace if necessary.
Regards, Jay
Need to down convert 16:9 to 4:3
Down-conversion Capability
The HVR-1500 has a built-in down-conversion capability that
allows 1080i recordings to be output as 480i and 576i signals from the
i.LINK and SD-SDI interfaces. These signals can also be output from the
analogue component, composite, or S-Video connectors. This allows 1080i
recordings to be edited using non-linear editing systems running DV
editing software or to be viewed on an SD monitor. When down-converting
the 1080i recording, the aspect ratio displayed can be converted from
16:9 to 4:3. Display modes can be selected from Squeeze, Letterbox, or
Edge crop.
DSR-1500 firewire port doesn't work. Any
It may be that the firewire cable has been inserted the wrong way round. Unfortunately this is a common problem as it is quite easy to do this especially when fumbling around with limited access behind the deck. Worst case scenario is that the Firewire circuit board has been fried! Firewire connection carries 30 volts, and if this connect to the wrong pins - pop goes the board. It's a £300 job to fix (I think). But first of all try pairing down any patching / connection to other equipement to a minimum to ensure that there is not something else in the chain that could be causing the problem.
DSR-1500
As far as I know, the deck you mention has a firewire port as standard.
Error code 09-028
Servo and tape path system error.
0 : Mode cannot be identified, or mode identification is
not necessary.
2 : Threading motor/FG/sensor
8 : Abnormal current detected.
If it’s not just a simple tape jam, then you have a problem with the loading mechanism. The best solution is to take the deck to a service center.
