Televison & Video Logo
Anonymous Posted on Jul 09, 2012
TV won't turn on
I have an AKAI 37” Wide_screen LCD TV/DVD Player Combo LCT3701AD. The red light is on, when I try to turn the TV on either by the remote or the power button on the TV the red light flashes red once but doesn’t go to green and the TV won’t come on. For the last two weeks I have unplugged the TV for about 5 seconds and plugged it back in and then the TV will turn on. As of today unplugging and re-plugging the TV in does not help. The TV will not come on. The red light is still on.
  • Anonymous Jul 13, 2012
    The problem was the power supply card. Replaced it and the TV is working fine.
  • Keshia Neal
    Keshia Neal Mar 16, 2014
    I'm having the same problem
Level 3:
Top Expert:
  • Akai Master 76,851 Answers
  • Posted on Jul 09, 2012
Akai Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15008675
Points
237762
It sounds that, the memory IC to your TV has damaged. This IC can be located very near to main system control IC. A very small one, with 8 solder terminals. Even though it is very small, function of it while the TV works is great. The work is a semi-skilled one, and you must have some knowledge in electronics to proceed.
2 Related Answers
Anonymous
  • Posted on Nov 16, 2009
SOURCE: TLA-04011c 40in. LCD TV: Red light is on. TV
I have the same TV and I just replaced the Capacitors. It came with 2 10000UF 10V caps and I put in 2 1000UF 35Volt caps from radio shack. Its like brand new. There is even a video on how to change them on You Tube.
Anonymous
  • Posted on Nov 22, 2009
SOURCE: LG 42 LCD no sound or picture
Did anyone find out the solution for this??????? I have the exact same problem with my LG 32 LCD. I only had it for a year and a half, and the green light blinks a few times and it shows no picture. Not even a red light when the tv is off. The same thing happened a couple weeks ago and by some miracle it started working again.
3helpful
I have a AKAI LCT3701AD 37 inch TV don't have the original remote control but bought a universal remote control but is not working Why?
YOU WILL STILL NEED TO PROGRAM THE NEW REMOTE FROM THE MANUAL THAT CAME WITH THE REMOTE. NORMALLY THIER ARE TWO WAYS TO PROGRAM A REMOTE EITHER MANUALLY OR TO DO IT AUTOMATICALLY. YES THE ORIGIONAL REMOTE IS ALREADY SET UP FOR YOUR MODEL OF TV BUT WITH THAT SAID TRY TO PROGRAM IT BY BOTH PARTS OF THE MANUAL. i AM USING A 55 INCH SMART TV AND HAVE DONE THIS AND ON OTHER SMART TV'S. ALSO YOU CAN GO TO THE WEBSITE OF THE REMOTE THAT YOU PURCHASE AND LOOK FOR VIDEOS ON HOW TO SET IT UP. IF YOU NEED MORE HELP LET SOMEONE HERE KNOW. GOOD LUCK.
I have an Akai 37 wide-screen LCD TV/DVD Player combo and it no longer turns on
Chances are it is the Power Supply. It is a Megmeet MLT386X which is hard to find. There are places that will repair the old one. You remove the covers running across the heat sinks and if the capacitors are bulging, the repairs are within the capability of anyone who knows how to use a soldering iron.
If you are handy with a soldering iron, LCDalternatives sells a kit with ALL electrolytic capacitors prone to fail for $15.95 plus shipping. I bought the kit and fixed mine. It took a couple of hours to unsolder and replace the capacitors.
Akai 32" wide screen lcd tv/dvd combo LCT3201AD
This may be an instance were the idea was great but the execution wasn't thought out. I've heard of several related problems that may be related. Both the TV and the DVD player tend to produce heat, not in great abundance, but together a sizable amount of heat. The power supply may have been ample for the TV at first but with the addition of the DVD player was not able to handle the extra load. If still under warranty you're all set. If not you might call Akai and see what they might be able to do for you.
3helpful
2answers
Neewd remote control number
well you say that you need to get another remote for you TV..you can buy it here at this link..http://www.amazon.com/Akai-LCT3701AD-Panel-Built-Player/dp/B000WEODRU ..ok
1helpful
NEED A FACTORY NEW OR USED REMOTE CONTROL
This place is pricey sometimes but has the best coverage of any I have found.
Akai Remotes
There are two different versions offered so a call or email might be worthwhile before buying.
37' akai tv combo dvd
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi
You have power supply problem. Please go to ebay and buy it cheaper price:
AKAI LCT3701AD POWER SUPPLY MLT386X REFURBISHED CHAIN
Thanks
GEORGE
Need model number & manual
According to the UPC code, this is Remanufactured Akai LCT2701TD 27 Inch LCD TV/DVD Player Combo
2helpful
2answers
TV ON STANDBY MODE
The blinking light on the front indicates a shorted part in the power supply. The power board will need to be replace or repair to restore the LCD functionality.
Let me know if you required further assistance.
Top Akai Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Accurate TV Repair...
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
