20 Most Recent Akai LCT3201AD 32 in. LCD Television Questions & Answers
It's not the fuse. Chances could be your PSU
Akai LCT3201AD... | Answered on Oct 13, 2017
If the service shops didn't charge people $200 to fix this I would not post.. But since they do - here's the $8 fix.
If you are electronically inclined, replace the three 1000uf 16v electrolytic capacitors in the power supply board located above the power switch. They are likely bulging out at the top and failed. They are the three in a row at the top - center of the board, located between the two black heat sinks. Make sure you get caps rated for 105c degrees! I recommend replacing them with 1000uf 25v caps. 35v caps will work but might be a tight fit as they are larger diameter.
Should cost you about $8 for the parts shipped. You can get them from partsexpress or digikey or any good local electronics store. Your local radio shack may have them but they won'y be 105c and thus may not last long.
Not handy, ask around, there is usually some electronic tweaker guy around that will install them for a few bucks.
This has solved the turns on / then off problem every time in the 3 I've done.
Akai LCT3201AD... | Answered on May 01, 2017
on the power supply board if it has capacitors that are raised in the center and not flat then that is you problem.this can be an issue with any model flat screen tv. 80% of the time this is what's wrong.same for computer monitors also.
Akai LCT3201AD... | Answered on Apr 30, 2017
Hi, it seems your TV requires technical service, it's seems a internal power supply issue but it should be checked. You can also check if the ventilation holes are not obstructed or if it has correct ventilation to avoid overheating.
Akai LCT3201AD... | Answered on Nov 02, 2015
Can't be predicted exactly. Might come around $45.
Akai LCT3201AD... | Answered on Feb 25, 2015
You either have the DVD player plugged into the wrong input on the TV or the TV not set to that input. If using HDMI change the HDMI cord to another HDMI port on the the TV. In an Extreme case you have a bad connecting cord (either HDMI or other type.)
Akai LCT3201AD... | Answered on Oct 27, 2014
Your TV need initilization. Contact the authorized service centre. Gopakumar Gopalan Google
Akai LCT3201AD... | Answered on May 28, 2014
DVD's (CD red book standard) are 120mm (12cm) in diameter the smaller 8cm disc's are the 1.4gb versions. not all "slot" loading mechanisms can accept these smaller type of discs. if you are trying to insert 120mm discs then there is a fault with the mech!
Akai LCT3201AD... | Answered on May 15, 2014
Check the speaker/s first. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. Pull up older posts. Surf the site with patience.
Akai LCT3201AD... | Answered on Apr 16, 2014
No it is not
Akai LCT3201AD... | Answered on Apr 08, 2014
Sounds like a bad main control board
Akai LCT3201AD... | Answered on Mar 28, 2014
Disassemble procedure to many popular brand TVs are given with illustrations. Surf the site with patience.
Akai LCT3201AD... | Answered on Mar 20, 2014
Akai LCT3201AD 32 in. LCD Television Logo
278 questions posted
Top Akai Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Akai Televison & Video
Most Popular Question
scott tv lct37sha hdmi
  • Televison & Video
