After initial power-up the access point had power led on,11.b.g led and 100 led flashing for awhile then stopped,since then the 11.b/g led and 100 led have not come on and i can't connect to the AP web interface because the unit doesn't connect to the router and it doesn't get IP address.i did reset it many times for 5 seconds for 30 seconds no change how can I link to the device to get it set up for use with my router(which is wireless ) because I want to provide wireless access to my internet in a remote location where my router's wireless doesn't reach.
SOURCE: 3crgpoe10075 status led blinking with no stop
hi ,,, i got yor problem. as ya said its not allowing ya to log nto it with security enabled. Ya can try to log into it with the ethernet cable as their wil be an ethernet LAN port onthe access point. I f ya know the default or the present ip of AP then ya can assign a static ip of the same range to yor computer like eg. ap is 192.168 .1.1 then your comp can have 192.168.1.10 and ya can log into it thru the ethernet cable and disable the security. i hope ya know how to assign a staic ip add to yor compuetr. or check the screen shots on brivers.com n select the "network connections" screen shots to assign a static ip address to yor' comp. feel free to chat with me on samrat101 thru yahoo or msn messenger or drop a mail on [email protected] for ny wless n ipphone issues -- take care ,, samrat
SOURCE: 3Com 7760 (3CRWE776075US) 802.11a/b/g...
Hi there
I think up to now you've been using someone else's Internet service, by picking up the signal wirelessly. You need your own Internet Service. You now connect your access point in the way the Internet Service Provider guide you. It is a different set up with cable (they provide a modem) or with BT (connection through your phone line).
