Stove top works fine and my oven wont come on.Stove top works fine and my oven wont come on.
AnonymousMar 23, 2014
stove top working but the oven and broiler does not heat up. when the digital control panel is selected for over and temp set the control panel lights up but oven does not heat up.stove top working but the oven and broiler does not heat up. when the digital control panel is selected for over and temp set the control panel lights up but oven does not heat up.
You can't post conmments that contain an email address.
THERE IS A WHAT I CALL A GLOW PLUG IN THE BOTTOM OF THE OVEN . WHEN YOU FIRST TURN YOUR OVEN ON THIS PLUG SHOULD GLOW RED AND VERY BRIGHT, IF IT DOESN'T YOU WILL HAVE TO REPLACE THIS ITEM AND THAT SHOULD FIX YOUR PROBLEM. WHEN YOU FIRST TURN THE OVEN ON THIS GLOW PLUG HAS TO GENERATE A LOT OF HEAT TO LET THE GAS VALVE KNOW THE IT IS OK TO OPEN IF THE GAS VALVE DOESN'T GET THIS SIGNAL FROM THE GLOW PLUG THE OVEN WILL NOT COME ON
your glow coil is wron out , need to replace it, you may see it glowing in there but it isnt getting hot enough, usually you can switch out the broil one for a quick fix to get you outta truoble. easy do it yourself problem
Usually, when an oven won't heat, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
Gas range repair aid -such as, my oven won't work or heat up, which style of gas oven do I have, the glow coil gets red but my oven burner will not light.
Some gas ranges may take 10 or so minutes to light.
Other than that you may have a defective glow bar ignitor.
If it glows and does not light the reistance in the ignitior has failed.
Most modern
gas ovens and many broilers use a "glow-bar" style of igniter that
glows red-hot to ignite the gas. If the igniter doesn't reach the
proper temperature, the gas valve won't open. You may need to replace
the igniter.
