Cars & Trucks Logo
Posted on Dec 06, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Passenger seat back will not move either direction
Mercedes 300 TE wagon power seats -- grandson was sitting in car moving seatback forward = recline = forward again and it stopped working completely. Seat can be adjusted for legroom but it can not be reclined -- it is stuck in its most forward position. Drivers seat works fine and no other problems with car.
  • John Weathers
    John Weathers May 11, 2010
    What year is this car? Do you have memory seats? If so try and use one of the memory buttons to put the seat back into it's (before grandson) position. If it goes back to original position the contacts in the switch could be burned.
Jason Johnson
Level 3:
President:
  • Mercedes-Benz Master 1,619 Answers
  • Posted on Jul 09, 2009
Jason Johnson
Level 3:
President:
Answers
1619
Questions
0
Helped
441505
Points
3913
Motor on the seat may have gone out, contacts in switch got dirty or worn, or assembly reached limit and stuck. Try sitting in it pushing back hard and adjust. If not youll need to replace switch,b take seat apart to fix or replace.
Mercedes-Benz CL550. The passenger right seat is frozen forward in the lift position. The seat will adjust back and forward but unable to take seat from lifted position.
Question edited for clarity, you forgot Herr. Benz.
Question moved from Spanish Car maker category Seat, (pronounced See-At) and nothing to do with car seats.
Can you hear the motor running? It can only be 5 things
Fuses
The Switch
The Motor
The linkage and drive
The Power Seat Module
Look underneath with light and mirrors. Or remove the seat to look.
Help in the link
https://www.google.com/search?q=mercedes+cl550+seat+lift+not+working
1helpful
2006 Chrysler PT Cruiser. Front passenger recline how far does it recline if the back seat is removed? Driving across country with a disabled person.
Question edited for clarity and errors.
Question moved from Seat, (Spanish car company) to PT Cruiser.
You would be better to fly, or put her in the back seat with lots of pillows and use the centre lap strap as a seat belt.
If you pull the seat all the way forward and remove the headrest, you should be able to see the maximum recline, but electric seats have a stop on them.
98 dodge dakota front passenger seat stuck up\\
First is there a lever on the side of the back if not did it ever recline? If it did used to recline and you can lift the lever all the way up try to bring the back forward and then see if it will go backwards.
2answers
The front passenger seat doesn't recline. The handle seems to work perfectly
This one is pretty easy to figure out. Your seatback isn't working correctly. Okay, I'll grant that my answer may seem pretty obvious, but, it really isn't, please hear me out.
When you yank on the handle the pawl that engages and locks the seatback into position, so that it won't move, is removed from its receiver. In this mode, the seatback moves freely back and forth as there is nothing to prevent its movement back and forth. You use this movement to find the exact seatback angle for you and when you have, you release the handle and the pawl is reengaged and the seat is locked. (There are various safety features involved that assure you that your seatback will remain locked in position. While the pawl and receiver are quite sturdy, you cannot depend on them alone in a crash. So, there is at least one interlock device that engages when the pawl goes home. The interlock helps to "rigidize" the seatback so it doesn't move.)
What is happening in your car's case, though is this, the interlock may be broken so that even if the pawl releases from the receiver, which it apparently is doing, your seatback remains locked because the linkage between the handle, pawl and the interlock is not working. You will have to have the interlock (it could be that device) and its linkages repaired before the problem will clear up.
2005 Nissan Altima - seat would do everything except recline. Hit the forward side and it has gone all the way forward (recline switch). Now, of course, the seat is not in a drivable position and...
If it will move in every other direction I would start by looking under the seat and check down in the seat trac for something lodged in it way.
Passenger seat doing the same thing
I have a 95 960 wagon and my seats have circuit boards
2003 Honda Accord sedan - passenger seat does not recline
You have to check the power to the recliner motor. If there is power, then replace the motor.
88 benz 560SEL passenger seat reclined wont raise back up
The set on the passager side of my 88 420SEL wont move up, and it make a noise about every 15sec like it is trying to move.
10helpful
2answers
My front seat will not move forward. It will recline, move up and down but it will not move forward. I've tried reseting the seat positions but nothing seems to work. my seat wont move forward is there a...
You can move the drivers seat back by turning on the power, getting in the seat and position your feet firmly on the fron flor with your back firmly against he seatback, and then engage the switch pushing back - while pushing like hell with your feet. You can actually hear the seat drive shaft turning while the seat moves back. The principle should be the same for moving forward, but pressure would have to be aplide to the back of the seat.
Top Mercedes-Benz Experts
ZJ Limited
ZJ Limited
xxxxxx xxx
Arnie Burke
Arnie Burke
Are you a Mercedes-Benz Expert? Answer questions, earn points and help others
