With acer emachine netbook
First of all, you need to charge the BH-503 before connecting it to your gadget. On the BH-503 after it is fully charged, go to your gadget and turn on its Bluetooth. Mind you some gadget do not have embedded Bluetooth in them;all you do is to but an external Bluetooth and insert it in the USB port. That will make your gadget discover your BH-503. Pair the 2 together, I mean your BH-503 and your gadget and your up and running!
Connect my tab(p6200) successfully but after 3-4 seconds my bh503 is turn off then restart my bh503 then successfully connect but then my bh503 turnoff. Please help and sorry for English
SOURCE: cannot pair Nokia N70 to Jabra BT150 bluetooth headset
turn on cell phone. activate bluetooth. press right button to search for bluetooth devices. Then press the on button and the volume UP button at the same time on the Jabra headset. The cell phone then finds the device. put in the password/pin (usually 0000). and voila! it works
SOURCE: Pairing NOkia BH-207 with Blackberry 8120
Power it off
Press the power on button for at least 10 seconds, until it keep the blue ligth on and then pair it with your BB
SOURCE: My nokia E63 wont find bluetooth headset
I had a similar problem with my headset.. but found the solution.. I am using Jabra 2010.. ok.. so just switch "off" the headset...go to the pair menu on e63.. then switch on the headset.. and then look for new pair devices option.. voila it came up. hv been trying for almost 3 weeks before i got the sequence right.. somehow if u had switched the headset on beforehand.. it wouldnt recognise it only.. the solution is here at jabra website .. although.. they dont hv e63 listed .. but the same procedure for e71 worked fine for my handset..
SOURCE: trying to pair nokia x6 with nokia BH-214
You have to hold the button down on the headset controller for approximately 6 seconds until the little LED on it flashes blue very quickly. The X6 will see it and match a pair automatically. If you just switch the headset on and the light flashes green the x6 will ask you for a passcode ... it doesn't matter what you put in (it seems) even '0000' ....it won't match the pair. HTH
