20 Most Recent
Alcatel Mini Bluetooth Headset NMINSTH4C2ALC Wireless Headset Questions & Answers
Alcatel universal bluetooth headset manual
I don't know if this will help but try this:
Make sure the headset is charged up.
On your phone, go to settings and find the bluetooth set up. Don't start it yet.
on the headset, press and hold the on/off button until the light comes on. It should flash blue and orange.
Now press the "add device" or similar language on your phone. It will search for the headset. Once it is found it will ask for a passkey. Try typing in 0000 (that is, four zeros). Press ok.
It should work now.
How to use bluetooth wireless headphone with alcatel smart phone?
There are a lot of alcatel phones. Do you have a model number? Basically, you go into the menu or settings, find the bluetooth menu and press "pair". Press and hold the power button on the bluetooth headphone until it "beeps".
The phone will ask for a pairing code, typically 0000. Try this or get me a model number of both the phone and bluetooth. Good luck!
I am unable to hear
Are you using a direct connection to the phone, or an amplifier? If you are using an amplifier they should have switch settings you can modify (for example a wheel labeled A-H or 1-8) make a test call to someone you know, and cycle through those settings until you can both hear each other.
How to wire a fridge thermostat
Wiring a fridge thermostat typically involves connecting the thermostat to the power source and the compressor. Here's a general guide for wiring a 3-pin thermostat:
- Identify the Pins: The thermostat will typically have three pins labeled 4, 6, and 3.
- Connect the Power Source: Pin 4 is usually the common (C) terminal, which connects to the power source. This could be the live wire from your electrical supply.
- Connect the Compressor: Pin 6 is often the normally open (NO) terminal, which connects to the compressor. This allows power to flow to the compressor when the temperature rises above the set threshold.
- Ground Connection: Pin 3 is commonly the ground (GND) terminal. This should be connected to the ground wire for safety purposes.
4/19/2024 7:20:26 AM •
Radio...
Answered
on Apr 19, 2024
Realistic scanner police codes
I recommend RadioReference.com, they have detailed lists from all over the United States. In addition to frequency lists, they also include live audio, HAM radio lists, licensing information and a lot more.
4/4/2024 5:32:44 AM •
Radio...
Answered
on Apr 04, 2024
