Projector worked earlier in the day and when we came back to turning on it was lifeless. LED light would turn on then shortly after to dim. The projector made a faint sound like it was going to turn off and the. It would power down. Now there is no power getting to it at all because the LED light goes from dim to off. Any suggestions?
SOURCE: infocus lp600 not working
HI-
MAke sure that cables are properly connected, it might be that it is not getting any signal from the source.
Hope this helps
SOURCE: Infocus projector won't turn on
From the infocus_lp650 manual
Table 2:
Red LED Behavior Explanation
One (1) blink The lamp won't strike after five (5)
attempts. Check the lamp and lamp door
installations for loose connections.
Two (2) blinks The lamp counter hours have exceeded
lamp life hours. Replace the lamp and
reset the lamp hours counter.
Optional Accessories Part Number
Three (3) blinks The projector has shut down the lamp.
Replace the lamp. Contact Technical Support
for repair if replacing the lamp does
not solve the problem..
Four (4) blinks The fan has failed. Replace the lamp (the
lamp module contains a fan). Contact
Technical Support for repair if replacing
the fan does not solve the problem.
Five (5) blinks The projector is overheating. Check for a
blocked air vent. Contact Technical Support
for repair if clearing the air vents
SOURCE: new lamp, no power!
if there are no leds lit, i'm surprised that it powers up. but if there is no light when the fans are running, it may be the ballast that needs replacing.
SOURCE: We have an Infocus X3 projector. It has been
the light tunnel is collapsing and needs to be replaced. contact an infocus authorized service center to either send it in for repair or purchase the part and do it yourself. try av solutions in ny. they're pretty good.
LED light is non existent, fans spin for a bit and then stop. Nothing happens when power is pressed on remote or device. We have unplugged it and plugged it back in. No warning for a bulb came on the screen earlier or anything of the sorts. Stumped...
