Samsung YH-925 MP3 Player Logo
Alex CAREIL Posted on Feb 10, 2007
Problem with YH-925
Hi, My Samsung Yh-925 don't want to work : Error message : "the device firmaware needs repair. Please connect to PC ...." I tried to connect it to PC. Not recognized by PC. Please, can you help me ?
  • jagoda1112 Jul 28, 2008
    i have the same problem and i did what you told me. i did hear the click and it still wont connect to the pc so i cant fix the firmware. what do i do now? i know my usb works bc b4 i tried installing i plugged in my camera and it worked perfectly fine. is there any way to fix my device now?
Anonymous
Level 1:
Problem Solver:
  • Contributor 10 Answers
  • Posted on Jan 01, 2008
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
10
Questions
0
Helped
2371
Points
12
It appears you need to use the rollback program, or the recovery program. But it also sounds like your usb cord is either broken or not plug in tightly. Press the usb adapter in untill you hear a click then plug it into the pc.
Samsung YH-925
have you tried the recovery utility as it may be able to recover your current firmware
Samsung hdd stuck
Hi, in my opinion1) rebuild your music album by music studio, 2)rebuild music database structure if first step not solve. using samsung yh-925 utility download from http://www.samsung.com/us/support/download/supportDown.do?model_nm=YH-925GS&mType=SW&vType=L&disp_nm=YH-925GS 3) update your device firmware if two steps fail.
Deleting files
If you need to run the recovery utility or format your YH-925, it needs to be in HDD Mode, not MTP mode. To temporarily restore the device back to HDD Mode:
  1. Ensure the YH-925 is powered off and disconnected from the PC
  2. Press and hold the >> button on the side of the device.
  3. While still holding the >> button, connect the YH-925 to your PC.
  4. YH-925 is restored back to HDD Mode until disconnected from the computer.
  5. Format the YH-925 by right clicking on the device in My Computer.
2helpful
YH-925 Windows media 11 update.
http://www.samsung.com/download/Model_Select.aspx?type=Digital+Audio+Player&typecode=8&subtype=HDD-Yepp&subtypecode=804&model=YH-925GS&filetype=SW&language= The file you are looking for is called: YH-925GS Samsung YH-925 Firmware Upgrade Utility for MTP (ver.1.0) Just a warning once you have downloaded it you won't be able to go back to the old version. But from everything i have read, the upgrade is the way to go. Good luck and hope this helps.
2helpful
Samsung digital audio player yh-925
i hav a problem in my samsung yh-925 it's capacity of hard disk is 20 gb when i open my audio player then the error "boot loader ver 1.10" soo please send me this solution fast i m waitng for your reply.
Samsung YH 925
Hi, run the recovery utility that you install from the CD. Reinstall firmware. C
1helpful
2answers
YH-925
my hy-925 audio player firmwire problem ans me plz????
My windows Xp will not find my samsung YH-925
Helpful website:
Top Samsung Audio Players & Recorders Experts
ZJ Limited
ZJ Limited
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
